Dgilmored 2 #1 Posted April 8, 2024 I need to replace the seals for all the shafts ( axels, brake, drive ) for my B80, model 71 - 08K801. I believe the trans. model is 103907. Does anyone know where I can source the seals or part numbers ? Share this post Link to post Share on other sites
ebinmaine 70,789 #2 Posted April 8, 2024 In this transmission section you can scroll down a few threads from the very top and find one that says "Bearings and seals cross.... ". Take a look at the second PDF and you'll find the numbers that you need. If that's a regular B80 transmission it should be three, 1-in seals and one, 3/4-in seal. We have two vendors you could try. K&B or Wheel Horse parts and more. You could also take those numbers in the chart and have someone local to you cross reference them. 1 1 Share this post Link to post Share on other sites
