CRF857 125 #1 Posted April 3, 2024 Anyone have an easy fix for a stuck towing valve? Recently acquired a 1277 and cannot budge the towing valve. Share this post Link to post Share on other sites
Ed Kennell 39,715 #2 Posted April 3, 2024 to the Wow, I never had a problem with that type tow valve. Did you try to loosen the large nut? Share this post Link to post Share on other sites
lynnmor 7,471 #3 Posted April 3, 2024 There is no evidence that you are soaking it with penetrating oil. 1 Share this post Link to post Share on other sites
CRF857 125 #4 Posted April 3, 2024 1 hour ago, Ed Kennell said: to the Wow, I never had a problem with that type tow valve. Did you try to loosen the large nut? It turns about 60 Degrees and stops. Share this post Link to post Share on other sites
CRF857 125 #5 Posted April 3, 2024 1 hour ago, lynnmor said: There is no evidence that you are soaking it with penetrating oil. It is at this moment Share this post Link to post Share on other sites
moe1965 750 #6 Posted April 3, 2024 I took some sticky adhesive like modeling clay and made a welll with it on the bottom so penetrating oil could sit in it i used aerokroil or kroils oil also let it sit for a few days it backed out with very little effort. Before doing that I used a little heat which I really didn't want to do and everything thing else I could think of with no results. Don't force it it could get ugly. Good luck keep us informed 1 1 Share this post Link to post Share on other sites
Lane Ranger 11,069 #7 Posted April 3, 2024 6 hours ago, CRF857 said: Anyone have an easy fix for a stuck towing valve? Recently acquired a 1277 and cannot budge the towing valve. my neighbor placed a larger vice grips pliers on the value and drive it around for a couple weeks and it loosened up! Sounds like the easiest , unstressful way to getting I it back in good operating shape! Share this post Link to post Share on other sites
peter lena 8,967 #8 Posted April 3, 2024 @CRF857 ever heard of KROIL OIL ? get some and get in in the turn point , so it sits flush with the top of the nut , let it sit , a day or two , like a small pipe wench , 10 inch , and a steel pipe convincer , on the wrench , just the solid leverage , should easily move that . let the kroil do the work . pete 1 Share this post Link to post Share on other sites
daveoman1966 3,768 #9 Posted April 4, 2024 Use a crescent wrench to remove the entire valve. Clean it up and refit as shown here. Be sure the black O-ring and the white Split ring are useable. PS--the tow valve STEM will turn 360 degrees. 2 1 Share this post Link to post Share on other sites
wfrpalm 218 #10 Posted April 4, 2024 15 hours ago, CRF857 said: It turns about 60 Degrees and stops. Isn't that all it is supposed to turn? Share this post Link to post Share on other sites
CRF857 125 #11 Posted April 4, 2024 1 hour ago, wfrpalm said: Isn't that all it is supposed to turn? The nut would only turn about 60*. The shaft not at all. Share this post Link to post Share on other sites
pfrederi 18,153 #12 Posted April 4, 2024 (edited) Turn the nut as far as you can and then start soaking. Give it time couple of days. Heat would be a last ditch effort as it will probably damage the O ring and backer. As mentioned above the valve will turn 360 The O rings are Dash#113 the backer ring is available from McMaster but you have to buy 50... Edited April 4, 2024 by pfrederi Share this post Link to post Share on other sites
peter lena 8,967 #13 Posted April 4, 2024 @pfrederi also like a super lube on the o rings , temp range / chemically correct for application . https://www.zoro.com/super-lube-4-oz-hydraulic-oil-bottle-68-iso-viscosity-80w-sae-52004/i/G2272326/? local H/W store , made for hydraulic applications , note temp range , terrific in / on cable slide applications , pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,173 #14 Posted April 4, 2024 Any heat should cause the cast iron case to expand and hopefully allow a penetrant in. Have a hot air heat gun or hair drier? Will take longer but will not overheat. 2 Share this post Link to post Share on other sites
daveoman1966 3,768 #15 Posted April 4, 2024 As I've shown, that 'nut' is just a COLLAR of the Valve BODY. Unscrew that COLLAR against the ROLL PIN, then unscrew that valve body some more, then the collar...until the entire valve body is removed. 1 1 1 Share this post Link to post Share on other sites
CRF857 125 #16 Posted April 4, 2024 9 hours ago, daveoman1966 said: Use a crescent wrench to remove the entire valve. Clean it up and refit as shown here. Be sure the black O-ring and the white Split ring are useable. PS--the tow valve STEM will turn 360 degrees. First of all thanks for the images of the valve. I was apprehensive about what was going on in that corner now that I know what it’s like underneath I will get it unstuck eventually right now the nut is completely loose but the valve itself will still not turn. I’m still soaking it and trying every so often with some pressure. 1 2 Share this post Link to post Share on other sites
pfrederi 18,153 #17 Posted April 4, 2024 Time is your friend Share this post Link to post Share on other sites
squonk 41,887 #18 Posted April 4, 2024 Tap lightly on the outside of the case where that valve is (to set up vibration ) and spray some more. Old plumbing trick to loosen stuck pipe threads. 1 Share this post Link to post Share on other sites
pfrederi 18,153 #19 Posted April 4, 2024 Had this unit sat for a long time??? Thinking tow valve is about the high point of the system. Over time fluid drained down and some condensation formed around the barrel of the valve creating rust. As other have said this is not a tow valve that seizes up very often. In any event a cpmplete drain an refill of the hydro when u get the valve out is in order. Share this post Link to post Share on other sites
CRF857 125 #20 Posted April 4, 2024 Applied a little too much pressure to the valve, and snapped the roll pln. Removed the rest of the pin and the nut. The nut is completely off and the valve does not move. Still soaking. Share this post Link to post Share on other sites
pfrederi 18,153 #21 Posted April 4, 2024 Soak and time do not rush this...Took a long tome to get stuck going to take more to get unstuck. 2 Share this post Link to post Share on other sites
pfrederi 18,153 #22 Posted April 5, 2024 Tap it on end with a hammer occasionally 1 Share this post Link to post Share on other sites
CRF857 125 #23 Posted April 6, 2024 Still stuck. Have been soaking and tapping on it. For some reason it is in there solid. 1 Share this post Link to post Share on other sites
moe1965 750 #24 Posted April 7, 2024 Don't give up keep soaking. Put a little 6 in pipe rench on it put some tension on it and tap the end of the toe valve. Do it both ways Share this post Link to post Share on other sites
CRF857 125 #25 Posted April 23, 2024 Still soaking and applying pressure. Still stuck! 1 Share this post Link to post Share on other sites
