snowhound 105 #1 Posted March 27 My 1987 416-8 model 31-16K803 doesn't turn off. The ground to the ignition switch is provided by the switch grounding against the dashboard and when the switch is in the off mode the ground, mag, and accessories are all active, I've checked and all are active. When running with the seat raised the seat light comes on but it keeps running and when I turn the switch to off the seat light go out and the amp meter goes to zero but the it keeps running. Any ideas as to what is causing this? Thanks Snowhound Share this post Link to post Share on other sites
Achto 27,609 #2 Posted March 27 34 minutes ago, snowhound said: Any ideas as to what is causing this? Bad connection between the switch and the coil. Wire maybe came off at the coil. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,047 #3 Posted March 27 Download this file. The ignition has it's own diagram Share this post Link to post Share on other sites
953 nut 55,321 #4 Posted March 27 There is a dark blue wire (or a black wire with a dark blue line on it) that goes to a plug heading to the engine. That plug has wires for the charging system and low oil switch. Check the condition of the dark blue wire going both ways from the plug, probably have a broken spot on it. If you don't find a bad spot then you may want to test the "M" terminal on the switch by grounding it with a small jumper connected to ground. 2 Share this post Link to post Share on other sites
peter lena 8,634 #5 Posted March 28 @snowhound https://www.google.com/search?q=alligator+wire+connectors&rlz=1C1CHBF_enUS866US866&oq=ALLIGATOR+&gs_lcrp=EgZjaHJvbWUqDAgCECMYJxiABBiKBTI very often use these on suspected ground issues , makes it simple , pete Share this post Link to post Share on other sites
953 nut 55,321 #6 Posted March 28 There is a blue wire that connects the magneto to the ignition switch and the PTO switch. If it is broken or not connected to the magneto it will not shut the engine off. Share this post Link to post Share on other sites
