ebinmaine
What's these parts/pahts/things??
ebinmaine
We got a small bin o stuff with the C121 Automatic from @PWL216
These things are not familiar to me or Trina.
Whut they be??
c-series don
I’ve no clue Eric, never seen that stuff before.
ebinmaine
Thanks Don.
We're the most concerned about the broken thing. We don't have the other half.
JoeM
the pin looks like the one used to connect the lift cylinder to the rock-shaft on a hydro.
  • Like 5
ebinmaine
Would it be used on a manual lift too?
JoeM
Not that I know of. The handle is attached directly to the rock-shaft.
You might have got some overflow parts. I have had that happen when folks sell me a machine and throw in the kitchen sink.
  • Haha 3
ebinmaine
Haven't found the sink..... yet.....
  • Haha 1
Pullstart
The blocks, do they fit a plow bracket bolt pattern?  Could have been massive drop brackets for more front lift?
ebinmaine
That's what we thought at first but there's nowhere near enough space between the holes
PWL216
@ebinmaine Hi Eric. I would disregard those parts. They were probably some parts on the bench that wound up in the box somehow. I don’t recall them coming off of the 121.
ebinmaine
I was kind of hoping you'd say something like that.
:lol:
BBT and I have only been into a select few of this body style and neither one of us could figure out what these were or where they went.
Spare parts box, it is!
Lee1977
Posted (edited)
That half looks like a broken wheel bushing, My tub trailer had bushings. Never seen one broken, I hammered them back in worn wheels with some shim stock for use on my wagon, and they didn't break. Must be some of that junk used on other brand Lawn Tractors.
Edited by Lee1977
wallfish
Posted (edited)
:text-yeahthat:
It's a broken wheel bearing/bushing
Blocks look like homemade spacers or something. Could they fit under the seat pan for something like that 416-8 to raise it for larger tires? Hole spacing the same?
Edited by wallfish
ebinmaine
4 hours ago, wallfish said:
:text-yeahthat:
Valid question. We can take a look at that next time we're messing with this tractor.
Lee1977
I made up some to put under the seat hinge, the seat back was too vertical .
ebinmaine
Understandable.
We remove the springs from all our own tractors.
This one being for other folks I'll leave the springs but I like that idea.
