ebinmaine
Brake shoe twisted ??
ebinmaine
Would you folks mind taking a look at this video and yell me what's up?
1978 or 9 C121 Automatic.
Bad brake band?
Something else?
Thanks!
  • Confused 1
Pullstart
Huh.  I’d say remove the rod and see if it’s sprung indeed.
c-series don
Text me tomorrow to remind me and I’ll go take pictures of the ones I have on my C - Series.
johnnymag3
There is an alignment issue.......rod is pushing band to the outboard side......it should be in a different Brake band, or a longer pivot...to push straightforward.
     There are different bands with multi holes as mentioned.
My .02
Edited by johnnymag3
peter lena
@johnnymag3 , think I  might try , flipping that band over , looking at it , the outside hole point , would be on the INSIDE  , for better alignment . just me , pete
  • Confused 2
Handy Don
14 hours ago, rmaynard said:
think you have the wrong band. Hole should be on the left. A double hole band is needed, or try drilling another hole.
The “brakeman” speaks!
rmaynard
2 hours ago, peter lena said:
...think I might try flipping that band over...
Not sure how you would do that Pete.
  • Like 4
peter lena
@rmaynard   brake rod is saposed to push straight back , correct ?  so if you unhook the push rod , turn the bracket over , so the rod hole is inside , of band  the push rod would , be pushing  against the strength of the band , inside thrust would hold the band in place / without slid  force angling it  to outside . thats what I see , BTW  , also use conveyor  belting , for my brakes .  just my view of the situation , pete
76c12091520h
Like the brake Dr. said :
  • Like 5
  • Excellent 2
rmaynard
After watching the video again, the brake band never returns to a straight, untwisted condition, leading me to assume that the band is damaged.
wallfish
Pull the band off and twist it back into shape. Drill a hole on the other side of the flange and adjust it properly then give it a try. The only cost is time. :twocents-02cents:
Edited by wallfish
  • Like 4
ebinmaine
My thoughts exactly.
I straightened the band while still on the tractor but it was too full of muck to leave it.
That's grass dirt grease etc.
While cleaning that all out the show fell out.
Off to the parts shelf I went. Found an older C series piece that has two holes AND a good shoe.
ebinmaine
Followup and solution:
  • Excellent 2
peter lena
@ebinmaine agree with you on the fix , typically it was a COMBINATION  OF ISSUES THAT CREATED THAT , another thing  that has really helped , related levers / linkage areas , is to firm up movement connections . regularly added washers , lube , have also gone to a HEIM JOINT , at awkward connections , like the male / female screw on , cut off original end , related DIE NUT , threading , put that on my clutch rod years ago , bombproof , don't  tell any body , pete
