clueless 2,993 #1 Posted March 13 What fluid does my 1960 burb use and how much and do I fill it through one of the seat spring holes? I had it written down some where but I can't find it . Share this post Link to post Share on other sites
Racinbob 11,081 #2 Posted March 13 1.5 qts. 80w90 gear oil or a weight thereabouts. 3 and 4 speeds all use 1.5 qts while 6 and 8 speeds call for 2 qts. 4 Share this post Link to post Share on other sites
Pullstart 62,887 #3 Posted March 13 Best to pop the shifter out and fill through there 5 Share this post Link to post Share on other sites
peter lena 8,629 #4 Posted March 13 @clueless personally like a ATF FLUID , refill and some road driving / shifting , for a trans clean up / out . use every gear , range , also lubricate related CLUTCH LINKAGE , for easier movement . use a razor blade to cut off old boot , like to lightly grease the INSIDE of new shift boot , at trans contact area , improves slide , and add a TYE WRAP , ABOVE THE BOOT , on the metal rod . so it can / will move with ease , reduce cracking / tearing . after some miles on that atf flush , drop that , and refill 89-90, like lucas CLIMBING GEAR OIL , it works better , pete 2 Share this post Link to post Share on other sites
Achto 27,577 #5 Posted March 13 (edited) 80 90wt oil. Filling through the shift hole works the best. Right below the axle on the right hand side is a pipe plug. Remove this plug and fill the oil until it starts to run out of the hole. Put the plug back & carry on. You can see the hole in this pic. Edited March 13 by Achto 6 1 Share this post Link to post Share on other sites
