chev0545 234 #1 Posted March 11 on a c-120 go to start it the solenoid clicks is it time for a new one. thanks 1 Share this post Link to post Share on other sites
953 nut 54,383 #2 Posted March 11 4 minutes ago, chev0545 said: solenoid clicks is it time for a new one Probably there is nothing wrong with the solenoid, There may be a battery issue or a cable issue. 2 Share this post Link to post Share on other sites
squonk 40,743 #3 Posted March 11 Battery, cable , starter or connection issue most likely. Best way to check is to take a voltage reading at the battery and work your way to the starter with the key in the start position checking for voltage loss. 2 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 141 #4 Posted March 12 Have you tested the solenoid to see if it is working? 1 Share this post Link to post Share on other sites
squonk 40,743 #5 Posted March 12 Another thing to check is make sure the solenoid has a good ground. I have seen where the ground is weak and the solenoid will click. But because of the weak ground the solenoid coil can't carry enough current to close the contacts. 3 Share this post Link to post Share on other sites
