Bob Bauer 27 #1 Posted March 5, 2024 Hi I have a sundstrand transmission that has a small leak on the bottom underneath in the middle and wondering if I can put a bottle of transmission stop leak for now until I can get to the problem.wondering if it would work and be safe for the transmission. Share this post Link to post Share on other sites
pfrederi 19,266 #2 Posted March 5, 2024 (edited) Absolutely NOT!! You will plug up any number of tiny orifices essential to operation. Edited March 5, 2024 by pfrederi 5 Share this post Link to post Share on other sites
ebinmaine 75,748 #3 Posted March 5, 2024 2 minutes ago, Bob Bauer said: be safe for the transmission. I don't think I'd want anything other than proper fluid in there. 4 minutes ago, Bob Bauer said: sundstrand transmission that has a small leak on the bottom underneath in the middle Only thing down there is the drain plug or the gasket between the case halves. Keep in mind the leaking fluid could be traveling from another location too. 5 Share this post Link to post Share on other sites
pfrederi 19,266 #4 Posted March 5, 2024 Clean the front of the transmission see if it is leaking down from the motion control 4 Share this post Link to post Share on other sites
pfrederi 19,266 #5 Posted March 5, 2024 Put a drip pan under her keep her filled up and use her until you have time to properly run down the leak. Leaks don't harm the hydro as long as you keep it filled... 4 1 Share this post Link to post Share on other sites
ebinmaine 75,748 #6 Posted March 5, 2024 1 minute ago, pfrederi said: Put a drip pan under her keep her filled up and use her until you have time to properly run down the leak. Leaks don't harm the hydro as long as you keep it filled... I'll second that. 1 Share this post Link to post Share on other sites
Bob Bauer 27 #7 Posted March 5, 2024 28 minutes ago, pfrederi said: Absolutely NOT!! You will plug up any number of tiny orifices essential to operation. Ok thanks 1 Share this post Link to post Share on other sites
Bob Bauer 27 #8 Posted March 5, 2024 29 minutes ago, ebinmaine said: I don't think I'd want anything other than proper fluid in there. Only thing down there is the drain plug or the gasket between the case halves. Keep in mind the leaking fluid could be traveling from another location too. Thanks 1 Share this post Link to post Share on other sites
Bob Bauer 27 #9 Posted March 5, 2024 19 minutes ago, ebinmaine said: I'll second that. Thanks 1 Share this post Link to post Share on other sites
Bob Bauer 27 #10 Posted March 5, 2024 19 minutes ago, ebinmaine said: I'll second that. Thanks 1 Share this post Link to post Share on other sites
kpinnc 16,188 #11 Posted March 7, 2024 Sundstrands that actually have a leak tend to do so at either the axle seal(s), or at the motion control lever. Axle seal leaks tend to travel to the lowest point before dripping, which makes it appear to leak at the gasket or towards the lowest part of the middle. Check fluid before and after each use, just to verify how much is lost. Never use the tranny if low in fluid. If the loss is minimal, just do as has been suggested and fix when you can. 3 Share this post Link to post Share on other sites
