JoeM 7,874 #1 Posted March 3 I have one of these UniStrut trolleys in the shop and it works really well and is inexpensive to purchase. Rated up to 600 pounds, nice for moving engines, decks etc. Just wanted to pass it along. Trolleys are $27 for a pair The strut is $36 for a 10' section. 3 7 Share this post Link to post Share on other sites
ebinmaine 67,506 #2 Posted March 3 This is excellent. We have one set up as well. Definitely recommend as a somewhat Mobile crane lifting device. 4 1 Share this post Link to post Share on other sites
953 nut 55,232 #3 Posted March 3 I made up an engine balancing device years ago using a short piece of Unistrut, some 1/2" allthread rod, a trolley and a couple of chains. When pulling or installing an engine in a car I could tilt the engine as needed to clear the firewall or radiator with ease. That will hold well over the rated 600 pounds. 6 1 Share this post Link to post Share on other sites
peter lena 8,629 #4 Posted March 3 @953 nut UNISTRUT is the word , we used them every ware in plant , down in the stock room area , we had 55 gal drums , filled with the most popular , maintenance pick up parts , you would g to the parts counter for specific , smaller parts , but what ever else you needed was in the hallway getting there , flanges , pipe hangers , conveyor materials , glass pipe connection flanges , nuts/ bolts , almost endless grab and go theory, we had hundreds of pumps / drive set ups , stem jacketed pump set ups , for heavy material in winter flow points ,SWISS LEWA POSITIVE GEAR PUMPS , always constantly adapting to the situation , to keep production running , those strut bends were made on a 100 ton bend press , incredible build point , pete 5 Share this post Link to post Share on other sites
953 nut 55,232 #5 Posted March 3 2 hours ago, peter lena said: UNISTRUT is the word Used a lot of it as an electrician on construction sites, Kind of a big kid's erector set. Stuff is incredibly strong and versatile. 5 2 Share this post Link to post Share on other sites
Wayne0 457 #6 Posted March 3 "Kind of a big kid's erector set." You got that RIGHT!! 5 Share this post Link to post Share on other sites
peter lena 8,629 #7 Posted March 3 @Wayne0 those also came in a MAGNATIZED version , for those that did not have a 3 rd. arm , pete 1 Share this post Link to post Share on other sites
ebinmaine 67,506 #8 Posted March 3 2 hours ago, 953 nut said: Kind of a big kid's erector set. Stuff is incredibly strong and versatile. I've read about using two pieces parallel then another hanging across 90⁰ from them. Makes it so the movable hoist can be located anywhere in a roughly 10 x 10 area. 3 Share this post Link to post Share on other sites
PWL216 889 #9 Posted March 3 Here’s my setup. Works great. Unistrut + Amazon Bearings + 1/4” steel. 3 3 Share this post Link to post Share on other sites
ebinmaine 67,506 #10 Posted March 3 5 minutes ago, PWL216 said: Here’s my setup. Very similar to ours. 2 Share this post Link to post Share on other sites
BBQVultureWings 100 #11 Posted March 9 B-Line Has a catalog you can download in .pdf format here: https://www.eaton.com/content/dam/eaton/products/support-systems/strut-systems-&-accessories/strut-system-catalog-2018.pdf Everything you ever wanted to know about Strut Hardware, products, Specs, Capacities, limits, Accessories etc. In my 25+ years of industrial electrical work experience, I thiMk the B-Line catalogs are about the best & most thorough of them all. I have been threatening to build a 4-way hoist in the garage for years now.... When I finally do it, This is the sort of product I would use as I doubt I will be lifting anything heavier than 600 lbs more like 350 or less for the most part & since I aint gettin' any younger, I better hurry up.... Hope that helps.... 4 Share this post Link to post Share on other sites
peter lena 8,629 #12 Posted March 9 @BBQVultureWings terrific ideas / go to source , terrifying to many , purists , could not even see it , lots of ideas / cures . you are a newbie , but you speak in the old school tongue , thank you , Pete 2 Share this post Link to post Share on other sites
