953 nut 55,189 #102 Posted May 6 3 hours ago, JPWH said: Randy, I'll take these and the points cover if still available. Just toss them in my truck along with the tiller, I will deliver them. 1 2 Share this post Link to post Share on other sites
squonk 41,067 #103 Posted May 6 1 hour ago, 953 nut said: Just toss them in my truck along with the tiller, I will deliver them. Yup. We'll toss that garden scratcher right into the front seat! 1 Share this post Link to post Share on other sites
JPWH 6,033 #104 Posted May 7 1 hour ago, 953 nut said: Just toss them in my truck along with the tiller, I will deliver them. Thanks again Dick. 1 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,330 #105 Posted May 7 Long shot here but I am looking for a front mounted thatcher for a zero turn Ferris mower. Share this post Link to post Share on other sites
Pullstart 62,834 #106 Posted May 7 @dkg520 I’ll grab those sickle parts from you! Share this post Link to post Share on other sites
953 nut 55,189 #108 Posted May 7 On 4/28/2024 at 6:13 PM, squonk said: igar lighter. Fill the hole in your dash and light your stogie during the cruise $20 Mike, if no one has bought it I will take the lighter. Never know when @stevebo may want to light one up. 1 2 Share this post Link to post Share on other sites
PWL216 889 #110 Posted May 8 (edited) Claimed K241 in parts. Maybe theres something usable here…free Edited May 26 by PWL216 Share this post Link to post Share on other sites
PWL216 889 #111 Posted May 8 (edited) Claimed Locally Green Chain Link fence. I think it’s 50 feet, but I could be wrong. I bought this at a yard sale, haven’t found a use for it, so off it goes! Free. Edited May 26 by PWL216 Share this post Link to post Share on other sites
whtractors24 3,116 #112 Posted May 8 Been thinking of putting up my custom built tractor for trade . It has a kohler k181 that’s been converted to fuel injection with a turbo . It runs excellent and is a head turner at shows . It can be hauled to the big show in June . Open to talk trades . IMG_4914.mov 2 5 3 Share this post Link to post Share on other sites
Monstrosity 1,127 #113 Posted May 8 49 minutes ago, whtractors24 said: IMG_4914.mo What transaxle did you use on this??? I'm intrigued Share this post Link to post Share on other sites
Monstrosity 1,127 #114 Posted May 9 (edited) 74 c series fender pan with tilt seat bracket I'll be there potentionally Friday but will be there Saturday. $50 SOLD to @shamuscull Edited May 9 by Monstrosity Sold Share this post Link to post Share on other sites
19richie66 17,500 #115 Posted May 9 (edited) 4 hours ago, PWL216 said: K241 in parts. Maybe theres something usable here…free I’d be interested in the clutch and air cleaner assembly. Will take all of it if no one else wants anything. Edited May 9 by 19richie66 2 Share this post Link to post Share on other sites
ebinmaine 67,422 #116 Posted May 9 On 4/28/2024 at 6:13 PM, squonk said: Breakerless ignition. Tractor had bad trigger. Found the wire chafed behind the bearing plate. Don't know if that's what took out the trigger.Repaired wire tested stator and coil with ohmmeter. Both tested ok. Comes with correct ignition switch too and mounting screws $25 @squonk I'd take these and that plastic fuel tank if you'd be so kind as to pass them to @wallfish John @PWL216 Paul if you want to save yourself from hauling those weights to PA I'd be happy to throw a hunnitt dollah bill your way next time we connect. 1 Share this post Link to post Share on other sites
JoeM 7,873 #118 Posted May 9 Onan 18HP was on a Sears Garden Tractor Test Ran on Tractor Good. $175 1 Share this post Link to post Share on other sites
Bill D 1,917 #119 Posted May 9 30 minutes ago, JoeM said: Onan 18HP was on a Sears Garden Tractor Test Ran on Tractor Good. $175 How long is the crankshaft on that? Is the mounting bolt pattern on the base and PTO side the same as the P216? Share this post Link to post Share on other sites
JoeM 7,873 #120 Posted May 9 11 minutes ago, Bill D said: How long is the crankshaft on that? Is the mounting bolt pattern on the base and PTO side the same as the P216? I can check tomorrow. Share this post Link to post Share on other sites
PWL216 889 #121 Posted May 9 11 hours ago, ebinmaine said: @PWL216 Paul if you want to save yourself from hauling those weights to PA I'd be happy to throw a hunnitt dollah bill your way next time we connect. Share this post Link to post Share on other sites
PWL216 889 #122 Posted May 9 All yours @ebinmaine 1 Share this post Link to post Share on other sites
ebinmaine 67,422 #123 Posted May 9 27 minutes ago, PWL216 said: All yours @ebinmaine Thanks Paul. I'll see if I can get my Ole Ball n Chain to make up a burger 🍔 or two. 3 Share this post Link to post Share on other sites
Pullstart 62,834 #124 Posted May 9 (edited) 2 hours ago, ebinmaine said: Thanks Paul. I'll see if I can get the one who hauls my Ole Ball n Chain around to make up a burger 🍔 or two. there, I fixed it! Edited May 9 by Pullstart 5 Share this post Link to post Share on other sites
pfrederi 17,725 #125 Posted May 10 Mold board plow 10" No idea what brand... Been on the shelf for several years I have clay and rocks and no need for the plow. $50 2 1 Share this post Link to post Share on other sites
