Chris-laf
I need help
Chris-laf
Looking for some ignition parts for 1969 wheel horse gt 14 I'm in search of an ignition coil as well as a pickup anything would be appreciated information on where I can find them or if you have one for purchase - thank you
rjg854
You can post in our wanted section if the classifieds and that will get you. Maybe what you're looking for.
ebinmaine
Unless you're specifically trying to keep original form you could likely change over to points for less money.
  • Like 4
WHX??
:text-yeahthat:
https://www.wheelhorseforum.com/classifieds/wanted/
953 nut
:WRS:
The breakerless ignition is wonderful until it quits working, then it has to go. I wouldn't want to spend money and time on a half century old electronic part when I could convert the engine to reliable battery powered ignition with a coil. Check out this post.
  • Excellent 4
ebinmaine
:text-goodpost:
Chris-laf
What would be necessary to switch to points I'm doing my best to learn just recently got into tractors more specifically wheel horses anything helps thank you
WHX??
Not sure as I have never done this conversion but I can :WRS:.
You came to the right place to get answers.
Chris-laf
So far I have definetly found great information just wish parts were easier lol
ebinmaine
No worries on the parts really.
Just need to get accustomed to looking at the right place.
Take a look at the thread posted above. That'll show you what needs doing.
pfrederi
Have you tested the components.  Coils are easier to find if that is the problem
 The tester is a couple of D cell batteries  and old school flashlight bulb
Edited by pfrederi
Chris-laf
Haven't tested it quite yet what how would I need to run the batteries and flashlight bulb in order to check
953 nut
First you should test the system you have to confirm it is in need of replacement as @pfrederi suggested. Follow the steps outlined in the attached information he gave you. You won't know what is good or bad without TESTING IT.
If you need to replace the ignition system you would need an internally resisted ignition coil, ignition points, points push rod and a condenser.
The post I attached to reply #5 covers the process step by step, take a couple of minutes and read it.
pfrederi
   Tape a wire (blueline) to the batt + use the other end of it and the end of the black wire from the bulb as probes for the tests.
kpinnc
I have that same breakerless system on my Bronco 14. The only time I had issues with it were when the very tiny tab on the bottom of the coil got corroded, weakening the contact from the trigger. A brass brush cleaned it up, and some CRC (or contact grease) kept it from coming back. That was several years ago.
That tiny trigger contact on the bottom of the coil seems to be the weak point on these things. Make sure it's clean and the wire terminal is crimped so it fits snug.
Good luck!
Edited by kpinnc
Chris-laf
Turn the engine over after connecting the blue wire and black wire to the coild correct and hope for the light to turn on?
pfrederi
Please read the directions this is done with everything disconnected and off the engine.  You can damage the trigger if you do it incorrectly
Edited by pfrederi
