953 nut 55,165 #1 Posted February 21 Build your own tractor The Victor Traction Gear Company of Loudonville, Ohio developed a unique opportunity for farmers or others wanting a tractor to build their own. In 1913 they provided a KIT to allow you to use whatever engine (Primarily Hit & Miss at the time) you had and a bit if ingenuity to build a tractor. The kit weighed about a thousand pounds and would be shipped by rail. There were apparently no dealerships and the purchaser paid the freight charges. I haven’t been able to find any sales information or pricing. The kit consisted of differential and transmission gears, traction wheels, freight wheels, axles, steering gear parts, clutch sprockets, chain and other appliances for converting gasoline engines into tractors. You made your own wood frame and used whatever engine you wanted. The transmission had one forward speed and a reverse gear. It was not intended to be used in the fields for plowing although it could pull a heavy load. The Victor Tractor was a drivable self-propelled power source made for hay baling, grinding, threshing, filling silos, powering saw mills, and other belt work. Engines of that time had a belt pulley and clutch built in. 9 5 4 Share this post Link to post Share on other sites
