Diesel Actual 4 #1 Posted February 16 I have an 856.currently it has Rear tire 23 x 8.50 x12 Front tire 16 x 5.50 x 8 I want to swap these two skinnier tires. I would also need new rims I think the 854 model has skinnier tires. What size are these tires and rims and where would I get them? I can’t seem to find anyone who sells wheel horse rims what is the measurement of the bolt pattern? Is there a discussion on tires on this site? I can’t find it. Thank you. Share this post Link to post Share on other sites
ebinmaine 67,424 #2 Posted February 16 Rear bolt pattern is 5 x 4.5. Lots of trailer wheels are made that size. To find a used set you could place an ad in our classified section. Or Contact one of our vendors like @76c12091520h Brian Or A to Z in PA. 3 Share this post Link to post Share on other sites
Handy Don 12,213 #3 Posted February 16 (edited) 1 hour ago, Diesel Actual said: I would also need new rims I think the 854 model has skinnier tires. What size are these tires and rims and where would I get them? The 854 came with 6.00x12 tires on the rear and 4.00x8 on the front. 854 front and rear are both narrower than what you have, though with similar overall diameter. I believe what you have is stock sizes. The rear hub bolt pattern @ebinmaine cites will be the same for the narrower wheel. The front spindle diameter will be the same (¾”) for the narrower wheel though the hub width might be different so you may need a spacer on the tractor side if you mount the 854-style wheel. Edited February 16 by Handy Don 2 Share this post Link to post Share on other sites
Lee1977 6,656 #5 Posted February 17 (edited) What no one has said Wheel Horses have a 1" to 1 1/2" set back on the side next to the tractor. There a lot of garden tractor wheels from other models that the 5 on 4.5 bolt circle will fit, but most have 3" or more back set. Edited February 17 by Lee1977 1 Share this post Link to post Share on other sites
squonk 41,068 #6 Posted February 17 Any 6-12 rear wheel from a garden tractor will bolt on. 2 Share this post Link to post Share on other sites
Diesel Actual 4 #7 Posted March 25 so i guess i could just get a trailer tire that has 1 inch offset and a 5 x 4.5. bolt pattern . i cant find any wheel horse rims and tires with 6.00x12 tires on the rear and 4.00x8 on the front 1 Share this post Link to post Share on other sites
pfrederi 17,725 #8 Posted March 25 (edited) For 6.00x12 tires wheel horse used a 5" rim with a 1-3/8 inch back set (viewed from the outside the center flange ends just about an 1/2" from the drop center. Edited March 25 by pfrederi 1 1 Share this post Link to post Share on other sites
