peter lena
snoopin around for a short ,
peter lena
had an electrical  on/ off ,to a very solid , set up , so I thought ,  ended up putting new wire ends , into an electrical plug in, re arraigned wires , back to solid running .  sparky , pete
  • Like 6
  • Thanks 1
stevasaurus
I think I get what you are saying, but full sentences would help.  :handgestures-thumbupright:  Where was the short??
peter lena
@stevasaurus short was in the plug in connection , at dash to ignition switch , one of the wire ends was failing reliable connection . also wire was tight , enhancing the erratic action . replaced 2 wire ends with slide tabs , to hold in plug in . the original wire make up was not tight . pete
  • Thanks 1
squonk
Loose connection is an open not a short
  • Excellent 2
peter lena
@stevasaurus , changed the short to a long and the  connection was fine , thank you , Pete
stevasaurus
:ROTF:  Glad you found it Pete.  I grew up chasing opens and grounds and shorts working for Ma Bell.  Hang in there Mate.
  • Thanks 1
