TC10284 111 #1 Posted February 12 (edited) I'm working on fixing up a 308-8. I went to check the transmission fluid and found that the plastic tube is broken at the base. I'm not sure if there is a square base where I can unscrew it. I need to double check. I don't think there is anything I can grab onto, like with vise grips or something. But if there is not, how hard is it to remove the broken part from the trans case? It looks like: https://www.partstree.com/parts/toro-106448/ And also, importantly, is there a replacement like the original or an alternative? Edited February 12 by TC10284 Share this post Link to post Share on other sites
ri702bill 8,479 #2 Posted February 12 Check with Lincoln at A-Z tractors. He is in the Vendors section. There MAY be different length tubes (and dipsticks)..... Share this post Link to post Share on other sites
JoeM 7,874 #3 Posted February 12 1 hour ago, TC10284 said: is there a replacement like the original or an alternative? I probably got one PM your address and I will send it to you. They come out pretty easy. 1 1 Share this post Link to post Share on other sites
