Retired Wrencher
856
Retired Wrencher
Looking for info on fuel pump that has vacuum pump or pulse pump. Never knew they had these pumps because it is a 66? Never owned a 66 before. Does it take the same rebuild kit as the lever or arm to cam pumps? Will arm or lever pump work on these engines?
ebinmaine
Different kit.
The vacuum pulse pump you have requires only a small square diaphragm to be replaced.
We have two vendors here on Red Square.
@buckrancher
And
@rmaynard
I've used both and recommend either one.
Retired Wrencher
Thanks Eric getting close to firing up the K181. I just sent a PM to https://www.wheelhorseforum.com/profile/591-buckrancher/.
Edited by Retired Wrencher
rmaynard
@buckrancher
And
@rmaynard
I am not really a vendor for diaphragms. I just happen to have a few extras that I made while stuck in the house during the Covid pandemic.
Retired Wrencher
Thanks Bob senthttps://www.wheelhorseforum.com/profile/591-buckrancher/ a message if he does not have anyI will contact you. Thank you for the reply. I am thinking of trying the cam arm type to see if the engine will run? I have every thing else for it.
ebinmaine
It's come up on Redsquare about swapping from one style pump to the other in the past.
The part in question is the actual camshaft in a Pulse type engine.
I've not seen definitive proof that Kohler  always used the same cam on both engines.
I would NOT try to install a lever arm pump where a pulse pump was originally.
Order the correct gasket for the pulse pump.
It's very easy to install.
rmaynard
You can look into the hole where the pump mounts and see the cam shaft. If there is a lobe, you're good to go.
Edited by rmaynard
  • Thanks 2
Mike'sHorseBarn
I've used the @buckrancher diaphragms before and usually keep a few on the shelf. In fact I used one this week on my 854 pump and now I only have one left so it may soon be time for another order lol
As far as using a lever style pump I believe the cams have the lobe no matter if your engine has a vacuum pump or not. I only know that because I tried it on an 855 and I found one that worked. You have to use a pump with the offset lever.
Retired Wrencher
Thanks every one for the info. Hoping to fire it up this weekend?
