Vinnie 11 #26 Posted January 25, 2024 Yesterday I resolved the engine hunting problem by taking the top of the carburetor off and spraying gum out into jets and also compressed air. I just used it today and it started hunting again. I just brought this tractor so I think the gas was bad so I did my best to pump it out and replace it. I was thinking of getting a new gas filter and doing the same thing taking just the top off with the carburetor and compressor. Share this post Link to post Share on other sites
RED-Z06 2,720 #27 Posted January 25, 2024 18 minutes ago, Vinnie said: Yesterday I resolved the engine hunting problem by taking the top of the carburetor off and spraying gum out into jets and also compressed air. I just used it today and it started hunting again. I just brought this tractor so I think the gas was bad so I did my best to pump it out and replace it. I was thinking of getting a new gas filter and doing the same thing taking just the top off with the carburetor and compressor. Check for any corrosion or scale in the bowl section, do a new fuel filter, gently blow out the lines. Share this post Link to post Share on other sites
Vinnie 11 #28 Posted January 25, 2024 Thanks. Good idea about the corrosion. Share this post Link to post Share on other sites
GWNORTH 7 #29 Posted January 25, 2025 Onan P216 in my 416-8 Surging/Hunting Onan_Surging.mov Share this post Link to post Share on other sites
RED-Z06 2,720 #30 Posted January 25, 2025 6 minutes ago, GWNORTH said: Onan P216 in my 416-8 Surging/Hunting Onan_Surging.mov Remove the top cover off the carb, clean the brass pilot jet in the base section of the carb, its got a little flathead shape on top. 1 Share this post Link to post Share on other sites
GWNORTH 7 #31 Posted January 25, 2025 I followed CODY and LYNNMOR's giudance as mentioned earlier in this post. Removed Carb top (after removing choke cable and muffler shield). Lifted out floats and needle . Removed everything that was removeable, including the idle jet and cleaned everything. I used a piece of 18 gauge copper wire to get into the little nooks and holes. Flushed everything with Carb cleaner and buttoned it all up. A couple of hours invested, and it runs like a top. It won't let me add the video right now of it running , smooth as silk. Says I can only upload 3.97 MB. Share this post Link to post Share on other sites
GWNORTH 7 #32 Posted January 25, 2025 6 minutes ago, RED-Z06 said: Remove the top cover off the carb, clean the brass pilot jet in the base section of the carb, its got a little flathead shape on top. AND RED-Z06's advice! Share this post Link to post Share on other sites
GWNORTH 7 #33 Posted January 25, 2025 I didn't know exactly what the "fix" was, but I think RED-Z06 is spot on, about the brass pilot jet.... I pulled that and ran a few strands of wire through the length of it, then poked wire through the holes in the side of the jet. There was a very slight blockage near the tip, which came out after poking it a bit and blasting carb cleaner through it. I did go ahead and clean up everything else that I could get to. Thanks to the wheelhorse experts, I'm back in the seat. Share this post Link to post Share on other sites
RED-Z06 2,720 #34 Posted January 25, 2025 13 minutes ago, GWNORTH said: I didn't know exactly what the "fix" was, but I think RED-Z06 is spot on, about the brass pilot jet.... I pulled that and ran a few strands of wire through the length of it, then poked wire through the holes in the side of the jet. There was a very slight blockage near the tip, which came out after poking it a bit and blasting carb cleaner through it. I did go ahead and clean up everything else that I could get to. Thanks to the wheelhorse experts, I'm back in the seat. That tiny little hole in the pilot jet is so easy to clog, makes them run with a bad surge, had one that it would reclog a few times a year until i put the carb through a sonic cleaner, waited until i could commit to doing the valve lash, and reseal the intake while i had the carb off Share this post Link to post Share on other sites
GWNORTH 7 #35 Posted January 25, 2025 (edited) Right, there was some sludgy stuff at the bottom of the bowl too, that could get circulated around I guess. Edited January 25, 2025 by GWNORTH 1 Share this post Link to post Share on other sites
GWNORTH 7 #36 Posted January 25, 2025 Here is the video after cleaning up the Carb.... No more Surging/Hunting Oanan_NO_Surging.mov 1 Share this post Link to post Share on other sites
Handy Don 17,419 #37 Posted January 25, 2025 Onans sure sound sweet when they are running well! 1 Share this post Link to post Share on other sites
