davidherbert0007@gmail.co 1 #1 Posted January 20 I have a 416-8. I need axle ,Brake and Input seals. The Hubs are 2 set bolts. There is no numbers that I can find on the Tractor. Any help is appreciated. Share this post Link to post Share on other sites
wallfish 17,088 #2 Posted January 20 (edited) You can find the seal kits at Wheel Horse parts and more. Give him a call to ensure you get the right kit. https://wheelhorsepartsandmore.com/product-category/manual-transmissions/page/3/ Those seals can be replaced without opening the trans Edited January 20 by wallfish 1 Share this post Link to post Share on other sites
peter lena 8,779 #3 Posted January 20 @davidherbert0007@gmail.co https://www.zoro.com/palmetto-packing-7-12-in-removable-packing-extractor-1101/i/G2594417/?u6iyURCEpzmYt39R2m_R5Z4JVuMSbxy9C2xuaHs8aAsVgEALw_wcB&gclsrc=aw.ds this type of screw in packing puller make those seals easy to pull out , shop around , maybe HARBOUR FREIGHT , ETC , for it , use an ice pick type of drive in punch. just a tiny hole in the side of the seal , will let you screw in the puller , and remove seal , might get a piece of plastic pipe , thats the same size of seal face side . for a tapping area . glad you are on it . Pete Share this post Link to post Share on other sites
Lagersolut 682 #4 Posted January 21 Schematic of the my 1986 416-8 - 1 1/8 axles https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/toro/riding-products/1986/31-16k802-416-8-garden-tractor-1986# Share this post Link to post Share on other sites
