John Sullivan 24 #1 Posted January 18, 2024 Hello, Looking for input on the widest rear turf tire I can install on an original factory 520-8 speed rear wheel. Thanks John in Vermont 1 Share this post Link to post Share on other sites
kpinnc 13,720 #2 Posted January 18, 2024 19 minutes ago, John Sullivan said: Looking for input on the widest rear turf tire I can install on an original factory 520-8 speed rear wheel. 10.50 would be pretty wide, and mate to the (if correct on your tractor) 8.5 inch wide wheels that came on later 520 machines. You could go with 24x12-12, but they fit pretty tight under the fender. 2 Share this post Link to post Share on other sites
John Sullivan 24 #3 Posted January 18, 2024 Thank you for the info. John Share this post Link to post Share on other sites
Cee245 823 #4 Posted January 18, 2024 John, Keep in mind not all tires are exactly their claimed size. You can easily raise the fender a bit with washers if needed. Try to post pics! Good luck 👍 Share this post Link to post Share on other sites
John Sullivan 24 #5 Posted January 18, 2024 Thank you John Share this post Link to post Share on other sites
