AJ Desalvo 22 #1 Posted January 4, 2024 Good morning Members!! Just wondering… My research suggests that a Champion plug RCJ-8 belongs in my K181. A Champion H-10C was installed in the engine at the time I purchased my Horse.. Probably a mistake or maybe a performance issue?? I welcome your opinions and suggestions.. Btw.. This forum is fantastic!! Thank you all for sharing so much information!! 2 1 Share this post Link to post Share on other sites
953 nut 57,871 #2 Posted January 4, 2024 Thank you for becoming a supporter of Red Square. Your research was correct, the Champion J-8 is called for on the Kohler engines from K-90 to K-181. 1 1 Share this post Link to post Share on other sites
WHX?? 50,703 #3 Posted January 4, 2024 H-10 is the correct plug for big blocks tho. K241, 301 and up. Since the J-8 was such a common plug there are many crosses & substitutes should the rack be empty as often with my luck. 1 Share this post Link to post Share on other sites
squonk 42,517 #4 Posted January 4, 2024 2 hours ago, AJ Desalvo said: Good morning Members!! Just wondering… My research suggests that a Champion plug RCJ-8 belongs in my K181. A Champion H-10C was installed in the engine at the time I purchased my Horse.. Probably a mistake or maybe a performance issue?? I welcome your opinions and suggestions.. Btw.. This forum is fantastic!! Thank you all for sharing so much information!! I run Autolites #255 in small blocks and #216 in big blocks 1 1 Share this post Link to post Share on other sites
TonyToro Jr. 1,749 #5 Posted January 4, 2024 4 hours ago, WHX?? said: H-10 is the correct plug for big blocks tho. K241, 301 and up. Since the J-8 was such a common plug there are many crosses & substitutes should the rack be empty as often with my luck. 1 Share this post Link to post Share on other sites
JoeM 7,923 #6 Posted January 5, 2024 19 hours ago, squonk said: I run Autolites #255 in small blocks and #216 in big blocks I like the autolites too! Good quality that h10 is just a touch hotter then the j8 if it ran good on the h10 pull lever B. And if you want a hotter plug a nice replacement for the 216is the autolite 437 If you are getting fouling from a combination of a tired engine and wonderful high quality gas. A hotter plug will help I know we do little stop and go driving but this shows how colder vs hotter works. 2 1 Share this post Link to post Share on other sites
