Alan Mard 9 #1 Posted January 1, 2024 What is the best lubricant for the chain on a single stage wheelhorse snowblower? Thank you in advance. Share this post Link to post Share on other sites
Wayne0 1,418 #2 Posted January 1, 2024 I use Chesterton Chain Lube on all my chains. 2 Share this post Link to post Share on other sites
ri702bill 10,557 #3 Posted January 1, 2024 Our resident Lubrication Guru, @peter lena, aka "Slippery Pete" would be one of the best to answer this. I for one, use the Lucas Red n Tacky grease - slather it on all surfaces of the chain to lubricate and keep moisture out. Does a good job not getting slung off.... And..... Welcome. 3 Share this post Link to post Share on other sites
peter lena 9,554 #4 Posted January 1, 2024 @Alan Mard , like a specific chain lubricant , made for that , always had some on it , so it was never dry , also resprayed it after use . used to use LUBRIPLATE chain / cable , before it tripled in price , NAPA , has the MAC,S brand of aerosol lubricants , # 1370 chain / cable spray , price about 8.50 $ they also have the # 1366 open gear lube , like that for rustproofing , been experimenting , also get after the idler pully frame just behind blower , its a metal to metal fit , lubricate that , have also put a stiffer spring on that set up , the freer movement , and pull , makes it work better , lubricate the bottom of the blower chute , and related , Chesterton lubricants are good , just the fact that you are , actually doing something to enhance function , stay at it ! 1/2" chain deflection on the blower . thanks @ri702bill and @Wayne0 for the reply's , did a number of functional gains on my blowers , wonder if we will get some use this year ? plows are ready , pete 4 Share this post Link to post Share on other sites
Wayne0 1,418 #5 Posted January 1, 2024 (edited) Grease is good, but it's too thick to get into the pins. Picks up grit too. Dedicated chain lube is best, as @peter lena said. Edited January 1, 2024 by Wayne0 1 1 Share this post Link to post Share on other sites
grinchsr 653 #6 Posted January 2, 2024 I have been using TriFlo on my chain with good results. 1 1 Share this post Link to post Share on other sites
Racinbob 12,422 #7 Posted January 2, 2024 I've always used whatever chainsaw bar lube I have on the shelf. 2 1 Share this post Link to post Share on other sites
peter lena 9,554 #8 Posted January 2, 2024 @Alan Mard all others referring to blower chain lubricant , most of what I see is rusty neglect , its almost too easy to eliminate that . a regular chain specific lube will work , personally suggest , a PENETRATING aerosol first , MAKE THE RUST RUN OUT , FIRST . nothing magic about maintenance , just look at what its SAPOSSED TO DO . rarely see a throttle / choke cable that works , almost a brag point on failure areas . done a number of blowers , tweaked / enhanced every movement point , went from failure to bombproof . that belt pulley frame , is loaded with , drag areas , mounting / pulley failures , effect of change / detailing / electrical lugs , on chute cable pull points . like Lucas anything , it stands up . regularly , washer up , sloppy movement points , lube , then also set it up so , look at every intended movement point , super lube oil , about 6$ , H/W store small bottle , use that on all your cables , check temp range , have also added light spring pull to cables / lever point , pull to close , spring pull is always assisting the action , tell me how that works , often its look right at you , get oily , Pete Share this post Link to post Share on other sites
Alan Mard 9 #9 Posted January 3, 2024 On 1/1/2024 at 3:34 PM, peter lena said: @Alan Mard , like a specific chain lubricant , made for that , always had some on it , so it was never dry , also resprayed it after use . used to use LUBRIPLATE chain / cable , before it tripled in price , NAPA , has the MAC,S brand of aerosol lubricants , # 1370 chain / cable spray , price about 8.50 $ they also have the # 1366 open gear lube , like that for rustproofing , been experimenting , also get after the idler pully frame just behind blower , its a metal to metal fit , lubricate that , have also put a stiffer spring on that set up , the freer movement , and pull , makes it work better , lubricate the bottom of the blower chute , and related , Chesterton lubricants are good , just the fact that you are , actually doing something to enhance function , stay at it ! 1/2" chain deflection on the blower . thanks @ri702bill and @Wayne0 for the reply's , did a number of functional gains on my blowers , wonder if we will get some use this year ? plows are ready , pete Thank you very much! Extremely helpful! 1 Share this post Link to post Share on other sites
Alan Mard 9 #10 Posted January 3, 2024 On 1/1/2024 at 3:35 PM, Wayne0 said: Grease is good, but it's too thick to get into the pins. Picks up grit too. Dedicated chain lube is best, as @peter lena said. Thank you Share this post Link to post Share on other sites
Alan Mard 9 #11 Posted January 3, 2024 On 1/1/2024 at 12:54 PM, Alan Mard said: What is the best lubricant for the chain on a single stage wheelhorse snowblower? Thank you in advance. Thank you all for your responses. I greatly appreciate it! Share this post Link to post Share on other sites
