Wayne0
Battery maintainer
Wayne0
I recently bought a "maintainer" after several members recommended one. Any thoughts as to where I should mount this on a 520?
PWL216
Following….
ri702bill
Is the case water PROOF?? If not, it may not last....
Jon Paulsen
I would just mount it at a convenient location that doesn't get hot. Like not on the engine. If there's enough room, maybe just double stick tape it to the battery.
Wayne0
Yes, it is.
Wayne0
Posted (edited)
Maybe I'll mount it to the wall of the barn and run a wire with a plug at the tractor. Coil the wire when not in use. I'd rather have it onboard.
Pulling the machine into the (heated) garage tomorrow to check everything out from last winter before we get snow again. Oil, belts, lube etc. I'll see if there is a place to mount this thing.
Edited by Wayne0
Wayne0
Problem solved. 3M tape!
lynnmor
Your battery hold down is pushing the battery posts towards the cross brace.
Rick3478
I noticed that, too.  I don't have a 520, so don't know what's normal, what with all the extra gauges, but it looks sort of backwards from what I'm used to.
Handy Don
Normal on ours has the hold down pushing the battery (in its plastic tray) back against a couple of flanges bent up from the “floor” of the hoodstand. The flanges keep the battery from getting pushed against the steering shaft or the gauges.
Wayne0
Actually, the rim of the battery is above the brace, so the posts can't contact it. The posts are bass ackwards on this battery, but it works.
doc724
My recommendation is to toss that battery minder out and buy one at Northern Tool, model #1500.  Last I checked they are about $60, if on sale about $35.  What's different about it?  I has an umbilical that you can unplug from the charger cord and permanently attach to the tractor battery (the umbilical has spring clips which work fine, but you can just cut them off and crimp on ring terminals).   The minder plugs directly into the wall outlet (or and extension cord) and there is a fairly long cord from the minder to the umbilical.  I used this for tractors and for cars that  are going to sit idle for extended time periods (3-6 months).  Also, you can buy the umbilical at most auto parts stores if needed for different machines or for your car.
pfrederi
I was looking at the instructions for a nice battery maintainer it specifically said "Do Not mount the maintainer on the battery"  Battery fumes/outgasses are corrosive and will damage it.
F. Marra 17
this is interesting as I never heard of mounting anything like this to any vehicle, tractors included.  I mounted mine high up on the garage door track. (past where the door opens to obviously) and the tender lead wire hangs down to where i park the tractor. It came with a quick connect.  the battery side lead has a rubber cover to prevent water or dirt while the tractor is in use and remains permanent on the batt terminals.  I have had this set up for 5 years now and have not had a problem or have chnaged the battery yet.  Starts on first crank. hope i didnt just jinx myself by typing that.
  • Excellent 2
SylvanLakeWH
:text-yeahthat:
:clap:
Wayne0
Posted (edited)
The instructions that came with it don't say that, however, it makes sense. It's a sealed AGM, but I'm going to mount it remotely any way. I have a cord similar to @F.Marra 17.
Edited by Wayne0
Lagersolut
peter lena
@Lagersolut   been using battery tenders for years , my 3 horses are set up , same way , on improvements , years .  that battery / pto lever area , is a GOLD MINE FOR IMPROVEMENT . Pete
