rmaynard
Enlarging a large hole
rmaynard
I have a blower cover from a K-161. I am trying to modify it for another project and need to expand the diameter of the front opening.
Considering that I don't have a machine shop, how would you suggest that I neatly increase the inside diameter from 6 inches to 6.25 inches?
wallfish
Mark the circle 1/8" from the edge.
 a grinder
You can get metal blades for a jig saw and clamp the saw upside down in a vice
Same for the grinder as it's probably easier to control the piece vs the tool
:twocents-02cents:
  • Like 6
rmaynard
Thanks for the quick replies. All very good. I'll keep looking to see what others come up with.
My idea is to take my 150mm hole saw (should fit inside of the 6" opening) and wrap it with self-adhesive 80-100 grit emory paper, slowly grinding and adding layers until I reach 6.25".
Sometimes these ideas sound good in my head, but in practice not so much.
Handy Don
1 hour ago, Racinbob said:
yank start 161
Bob, This modification to the mid-hitch has me very curious. Can you please explain & add pics from the other side? 😁
8ntruck
:text-yeahthat:  Probably a jack shaft for the mower drive.  Round hoods were built before the invention of the front mule drive.
Handy Don
I don’t see any sort of latching or mower frame, so this appears to be a complete “permanent” replacement  for the round hood style mid hitch, at least on this side, using a permanent bearing.
rmaynard
:offtopic: I think this thread has gotten off the track a little bit
  • Haha 2
  • Sad 1
ri702bill
But, I DO so like the picture of an 854 on Gopher Patrol duty..... :o   And now, back to our originially scheduled program...
CCW
@rmaynard The sandpaper idea has some merit.  Perhaps start with drawing the outside diameter of the new hole with pencil or marker and grind close to the line.  Then use your hole saw and sandpaper to bring it closer and finish with a file.
rmaynard
Good idea. Thanks
peter lena
@rmaynard  might try curved tin snips , draw , scribe ,your intended increase , try tin snips on a  trial piece , for  actual , cutting ability . done a lot of tin snipping , its a doable  thing , Pete
Pullstart
If you choose to use a drum Bob, the larger diameter will make it easier for keeping a smooth radius.  Small diameter tends to dig more.  You might not want to use too big a hole saw for a drum though, so it doesn’t grab ahold and dance the jig around.  Carbide cutters in a die grinder if they are too closely matched to a hole size will do that quicker than you can lay off the throttle.
peter lena
@rmaynard https://www.eastwood.com/throatless-shear.html?gad_source=1&gclid=CjwKCAiAnL-sBhBnEiwAJRGigsO9dJpnge15hUDibLnzm1gkD33iDt5Yn1ZSIvtwDzD4BsU1HdvJRhoCILYQAvD_BwE&wcid=18669317454&wickedid=629952193648&wickedsource=google&wv=4  , have a metal shop near you ?  used this on a regular basis , put the center hole on over the handle , to da !  made for that  ,   not suggesting you buy this , only a reference for a tool that was made for metal fabrication .  been there done that , Pete
OoPEZoO
That's awesome......well done :greetings-clappingyellow:
CCW
@rmaynard  Glad it worked for you.  Nicely done.
