Daron1965
23x8.5x12 tire pressure
Daron1965
Its been a few years since I plowed snow with a wheelhorse.  What rear tire pressure do you recommend with tire chains?
ebinmaine
In an air filled tire, 8 to 10 lb.
My fluid filled tires have zero air pressure.
  • Excellent 3
Jon Paulsen
:text-yeahthat:You only need enough air to keep the tires bead in place on the rim. Ran a Willy's Jeep ON road at 5 PSI for 33X12.50's.
  • Haha 1
ri702bill
MY fluid "filled" tires have a small air space - and I run 10 psi.... Helps swell the tire to "tighten" up the chains.
ebinmaine
Another advantage to the fluid filled tires.
The filling keeps the bead out towards the rim.
Our first attempt at fluid filling was about a year ago for my C160 Automatic Tractor.
23 x 10.50 x 12.
Should have held 7 gallons.
We used tubes. Started with new empty still flattened out tubes.
We kept relieving the air from around the stem.
Managed to get 8 gallons in one, just less in the other.
The fluid was actually under a little pressure when we were done.
We know this because it made a hilarious mess when we removed the pump hose to install the valve stems.
  • Haha 1
