Daron1965 644 #1 Posted December 15, 2023 Its been a few years since I plowed snow with a wheelhorse. What rear tire pressure do you recommend with tire chains? Share this post Link to post Share on other sites
ebinmaine 70,701 #2 Posted December 15, 2023 In an air filled tire, 8 to 10 lb. My fluid filled tires have zero air pressure. 3 Share this post Link to post Share on other sites
Jon Paulsen 291 #3 Posted December 15, 2023 You only need enough air to keep the tires bead in place on the rim. Ran a Willy's Jeep ON road at 5 PSI for 33X12.50's. 1 1 Share this post Link to post Share on other sites
ri702bill 8,963 #4 Posted December 15, 2023 1 hour ago, ebinmaine said: In an air filled tire, 8 to 10 lb. My fluid filled tires have zero air pressure. MY fluid "filled" tires have a small air space - and I run 10 psi.... Helps swell the tire to "tighten" up the chains. 1 Share this post Link to post Share on other sites
ebinmaine 70,701 #5 Posted December 16, 2023 16 hours ago, Jon Paulsen said: You only need enough air to keep the tires bead in place on the rim. Another advantage to the fluid filled tires. The filling keeps the bead out towards the rim. Our first attempt at fluid filling was about a year ago for my C160 Automatic Tractor. 23 x 10.50 x 12. Should have held 7 gallons. We used tubes. Started with new empty still flattened out tubes. We kept relieving the air from around the stem. Managed to get 8 gallons in one, just less in the other. The fluid was actually under a little pressure when we were done. We know this because it made a hilarious mess when we removed the pump hose to install the valve stems. 1 1 Share this post Link to post Share on other sites
