WHX?? 48,815 #26 Posted December 16, 2023 58 minutes ago, elcamino/wheelhorse said: Wonder if he used his tongue to test the quality of the gear oil? Ain't you got deck pullies to go bust up Waldo??? 'Twant Squonky told you how to bust them proper? 10 minutes ago, c-series don said: No shortage of sarcasm here today with this post! How's that Don? 2 Share this post Link to post Share on other sites
Ed Kennell 38,178 #27 Posted December 16, 2023 Make sure the ground is on a good clean metal surface as close as possible to the point you will be striking the arc. Path of least resistance ya know. You can remove the battery, engine, and all wiring, But with the ground at the wrong place, I would be more concerned about arcing thru bearings. 7 1 Share this post Link to post Share on other sites
WHX?? 48,815 #28 Posted December 16, 2023 24 minutes ago, c-series don said: Also not sure how @squonk knows that @Pullstart sleeps on straw, but whatever !……. Who knows Don ... Waldo also say Squonky checks Waldo's shorts for crap... says it's good Sqounky has a hobby. Me thinks Squonky has bedded down with Pullstart so he knows about the straw? i got my problem solved... thanks again Bill! 5 2 Share this post Link to post Share on other sites
WHX?? 48,815 #29 Posted December 16, 2023 (edited) 40 minutes ago, Ed Kennell said: Make sure the ground is on a good clean metal surface as close as possible to the point you will be strikingly the arc. Truth be told Ed I kinda wished I woulda had to go that route if nothing else to sharpen my welding skills. I can't toss the required 100 arrows a day to keep my bow skills up to date and goes even more for my welding skills. Edited December 16, 2023 by WHX?? 3 Share this post Link to post Share on other sites
Achto 27,577 #30 Posted December 16, 2023 (edited) 3 hours ago, WHX?? said: Broach the hubs, new hardware and call it a day for this girl for now. Gotta love it when seals leak and hubs slide right off. Glad you got this figured out. How's the gas tank coming along?? Now that you have that tractor ready for snow duty, you can get back to work on a 701 or an Amigo or ..... Edited December 16, 2023 by Achto 1 Share this post Link to post Share on other sites
squonk 41,119 #31 Posted December 16, 2023 10 hours ago, Achto said: Now that you have that tractor ready for snow duty, you can get back to work on a 701 or an Amigo or ..... 5 Share this post Link to post Share on other sites
953 nut 55,244 #32 Posted December 16, 2023 11 hours ago, WHX?? said: got my problem solved. Thanks for reminding us what the subject of this thread had been. I love threads that get totally derailed to the point where nobody remembers what the problem was in the beginning. The best part is that the solution to the problem had nothing to do with the subject line of welding! 8 Share this post Link to post Share on other sites
WHX?? 48,815 #33 Posted December 16, 2023 11 hours ago, Achto said: How's the gas tank coming along?? The 96 hr cure time is up so she gets gassed today. New sedimental bowl and plumbed. Next show season I'm gonna put the deck on for campsite mowing duty. 2 Share this post Link to post Share on other sites
ebinmaine 67,515 #34 Posted December 16, 2023 51 minutes ago, 953 nut said: solution to the problem Just learned about that torx bit for rounded allen heads recently. Hopefully when I run into this issue I'll remember to try it. 3 1 Share this post Link to post Share on other sites
WHX?? 48,815 #35 Posted December 16, 2023 Get a bit like Richard posted so you not hammering on a nice socket mounted one. I'd have look what size it is but it set in goodntite. 1 1 Share this post Link to post Share on other sites
