Handy Don 13,247 #26 Posted December 11, 2023 10 minutes ago, 8ntruck said: Nope. Was fear of retribution! Valid 2 Share this post Link to post Share on other sites
jay bee 912 #27 Posted December 11, 2023 to Great looking tractor!!! Going to be a great worker. 1 Share this post Link to post Share on other sites
CCW 1,323 #28 Posted December 12, 2023 I'm very envious of your FEL. Could use on occasionally, but not enough to justify buying one and modifying my 312-8. Plus I just do not have a good place to store it as I hate leaving any of this equipment outside. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,206 #29 Posted December 12, 2023 Tractor most likely a 1981 D-200 Automatic model 01-20KS00 as that is the only model number to start with 01. Two pages of links to files on the model https://www.wheelhorseforum.com/search/?&q=01-20KS00&type=downloads_file&page=1&search_and_or=or&sortby=relevancy I likely made an error here. Appears the model 01-20KS00 was used for 1980 and 1981. The serial number looks like a 1980. 2 Share this post Link to post Share on other sites
BuffaloD200 51 #30 Posted December 12, 2023 4 hours ago, gwest_ca said: Tractor most likely a 1981 D-200 Automatic model 01-20KS00 as that is the only model number to start with 01. Two pages of links to files on the model https://www.wheelhorseforum.com/search/?&q=01-20KS00&type=downloads_file&page=1&search_and_or=or&sortby=relevancy I likely made an error here. Appears the model 01-20KS00 was used for 1980 and 1981. The serial number looks like a 1980. Thank you! Share this post Link to post Share on other sites
BuffaloD200 51 #31 Posted December 13, 2023 (edited) Managed to use a sharpie to add a little contrast to the serial numbers 01-20KS00-7816 for the tractor 97-48FL01-05271on the FEL Edited December 13, 2023 by BuffaloD200 3 Share this post Link to post Share on other sites
BuffaloD200 51 #32 Posted June 29, 2024 Well I added a D160 to the mix. I really wanted that snowblower. Now I just need a belt for it. I've got the D200 running pretty good. Haven't gotten the FEL to move yet though. I freed up the pump, my thought is I need to rebuild the control valves. 2 1 Share this post Link to post Share on other sites
oliver2-44 10,233 #33 Posted June 30, 2024 2 hours ago, BuffaloD200 said: I freed up the pump, my thought is I need to rebuild the control valves. Most good commercial Hydraulic Shops should have the O-rings and seals to rebuild you hydraulic valve. 1 Share this post Link to post Share on other sites
BuffaloD200 51 #34 Posted June 30, 2024 (edited) It would appear that I have a D180, not D160. It has a Kohler twin. Edited June 30, 2024 by BuffaloD200 Snafu Share this post Link to post Share on other sites
