meadowfield
RJ-58 vs Suburban 400/551
oliver2-44
@meadowfield
Finally, here's the 551 Hood Sand Parts Drawing and some notes.
The 1/4 x 1-3/4 x 8-5/8 Flat Bar welds to the left side of the frame. it sits 1/2' inward and mounts directly against the round foot rest bar.
The 1/4 x 1-1/4 x 1-3/4 (2 required) They mount with an edge directly inline with the outer edge of the right side of the frame. One welds directly against the right round foot rest bar.  The other one welds to the frame  8-3/4 from the right foot rest bar.  This should result in the 2 tab having a 9" wide outside to outside dimension.  The hoods stand mounts to the outside of these 2 tabs.
The battery holder bar installs with 2 long 1/4" bolts that extend back to the 1/4" holes in the left side hood stand frame mount bar.
WH 1961 551 Suburban Hood Stand Drawing.pdf
meadowfield
On 12/26/2024 at 6:04 PM, oliver2-44 said:
@meadowfield
awesome thanks - when I shake this cold and fever, I will crack on
meadowfield
been on with making the brake and clutch linkage - do you have measurements?   also looking for the pulley size and belt length.
oliver2-44
Yes I can get you the clutch and pulley info.
oliver2-44
Going right to left.
Engine Pulley 2-1/2” OD x .750 ID
Idler Pulley. 3” OD x .389 ID.
It has a ball bearing inside it
Transmission Pulley  4” Od x 3/4” I D
Ill get a drawing made of the clutch parts
Will you need a drawing of any of the parts in the picture below.
meadowfield
Posted (edited)
wow - you are a star!!!   I think I'm good for now - maybe just the dimension of the clutch pedal....
thanks
Edited by meadowfield
oliver2-44
WH Suburban Clutch Parts 01-06-2025_14-45-13-970.pdf
@meadowfield
The Clutch Spring is 4-1/2" long overall
The coil section is 3-5/16" long
There are 46 coils with an OD of 0.572
The wire is 0.070
Edited by oliver2-44
