KZK 7 #1 Posted December 6, 2023 Hi again, I have a new problem. I have been able to get my Kohler engine K 241S to tick over but the moment I increase the revs it dies and or backfires through the exhaust. I have replaced the points, condenser and spark plug. Tick over is erratic. I have also tried taking off the patrol tank cap with no appreciable improvement. Initial settings for the main jet and slow running jet have been 2 full turns out. There is a good spark at the plug. Should the spark plug be a short reach? Share this post Link to post Share on other sites
Vintage_Wheel_Horse_Lover 18 #2 Posted December 6, 2023 should be champion H10c spark plug Share this post Link to post Share on other sites
953 nut 55,194 #3 Posted December 6, 2023 The Kohler engine service manual section 8 has information on adjusting the ignition points. The points gap also adjusts the ignition timing and should solve the problem you are experiencing. 1 1 Share this post Link to post Share on other sites
23 Reo 229 #4 Posted December 6, 2023 Your issue may be lack of fuel. I would clean the carburetor, replace the fuel filter and flush out the fuel tank. Make sure that you have a good fuel flow from the tank. 1 Share this post Link to post Share on other sites
fourwheelhorseman 279 #5 Posted December 7, 2023 It could also be a sticky valve… just a thought. Share this post Link to post Share on other sites
Rick3478 428 #6 Posted December 7, 2023 Sounds to me like a carburetor issue. The idle circuit is a separate thing and it seems to be working, but if the main jet is clogged you won't get any fuel to the venturi when the throttle plate opens. Also these can get a bit wonky if the throttle shaft bushings are worn, letting extra air leak in. I'd look for something along those lines. Share this post Link to post Share on other sites
KZK 7 #7 Posted December 7, 2023 Thanks to all for your advice will work through them all and let you know the outcomes. I have tried a Chinese replacement carb which does exactly the same as the original so I assume wear might not be the problem but thanks for all the suggestions. Have bought a new plug and will check the contact breaker as I think I set them on a reverse rotation!!! I also have left the ignition turned on and only realised this some time later when the coil was too hot to touch. Will it survive or will it need replacing? Share this post Link to post Share on other sites
Jon Paulsen 290 #8 Posted December 7, 2023 5 hours ago, KZK said: Will it survive or will it need replacing? If you have a meter, you should be able to check resistance across the coil. Someone might know the spec., or might be in the manual, but good enough test would probably be 5 or 10 ohms, unlikely kilohms, not megohms. Share this post Link to post Share on other sites
KZK 7 #9 Posted December 8, 2023 Thanks Jon have checked with the plug and still appears to be creating a spark at the electrodes 2 Share this post Link to post Share on other sites
richmondred01 2,237 #10 Posted December 8, 2023 Remove, clean, face (if required), lap and adjust valves. This is an overlooked procedure and is a fairly easy process. 1 Share this post Link to post Share on other sites
