Bow_Extreme 580 #1 Posted December 5, 2023 Well, this is a first. Couldn’t resist the selectable 4wd, 26” rear tires, power steering, and heavier front end loader. Also, much bigger tractor than the wheel horse. 5 Share this post Link to post Share on other sites
WHX?? 53,284 #2 Posted December 5, 2023 Didn't know Simplecity had a SCUT in 4wd. Looks to be a hi- test rig. Turf tires tho? 1 Share this post Link to post Share on other sites
Bow_Extreme 580 #3 Posted December 5, 2023 6 hours ago, WHX?? said: Didn't know Simplecity had a SCUT in 4wd. Looks to be a hi- test rig. Turf tires tho? Tires will be upgraded. Looking at building 15” rear wheels for this and installing 29” Tru-Powers. Then throw a larger set of AG’s on the front. 3 Share this post Link to post Share on other sites
Pullstart 68,518 #4 Posted December 5, 2023 Looks cool Matt! 1 Share this post Link to post Share on other sites
953 nut 62,971 #5 Posted December 5, 2023 (edited) Very nice lookin unit. With the weight box that far from the rear axle you can probably pop a wheelie if it's loaded up all the way. Edited December 5, 2023 by 953 nut fat finger 1 Share this post Link to post Share on other sites
Bow_Extreme 580 #6 Posted December 5, 2023 1 hour ago, 953 nut said: Very nice lookin unit. With the weight box that far from the rear axle you can probably pop a wheelie if it's loaded up all the way. I haven’t yet. That’s a factory weight box. They do have a factory suit case weight bar bracket that’s available. It’s closer to the tractor. I’ve been tempted to purchase this and the weights. Share this post Link to post Share on other sites
peter lena 9,552 #7 Posted December 5, 2023 @Bow_Extreme think I would shorten that weight box , support / base , the extreme weight LEVERAGE of that set up , will probably add to related stress cracking . also when you consider the front wheel size / set up , related bearings , spindle set up , pete 1 Share this post Link to post Share on other sites
WHX?? 53,284 #8 Posted December 5, 2023 7 hours ago, Bow_Extreme said: Tires will be upgraded. Looking at building 15” rear wheels for this and installing 29” Tru-Powers. Then throw a larger set of AG’s on the front. Good ideas... Give more ground clearance fer sure. 1 Share this post Link to post Share on other sites
