WHX?? 53,284 #26 Posted December 5, 2023 New way to respond to posts Don? Yer makin me blue... 2 Share this post Link to post Share on other sites
Handy Don 15,133 #27 Posted December 5, 2023 It was an experiment based on how I used to handle emails at work when I got 50 or more each day. In future, I”ll be sure to use RED 2 1 Share this post Link to post Share on other sites
WHX?? 53,284 #28 Posted December 5, 2023 (edited) Long as it's not green or yellow Noticed the lower pinion was pinned on so got the steering shaft off. Check out the fancy roll pin that was in it. Going to just grind the weld down flat. Get a cap from Lowell to hide the ugly and call it a day. Tried to remove the tank screws. Got one out and half the threads came with it. Going to seal as is and just enough sealer to cover the lower outside.. Edited December 5, 2023 by WHX?? 3 Share this post Link to post Share on other sites
ebinmaine 75,689 #29 Posted December 6, 2023 5 hours ago, Handy Don said: It was an experiment based on how I used to handle emails at work when I got 50 or more each day. In future, I”ll be sure to use RED Wish I could change text colors. from my phone. .... Share this post Link to post Share on other sites
ebinmaine 75,689 #30 Posted December 6, 2023 9 hours ago, Kenneth R Cluley said: . "Sorry EB" On one hand it has been open recently, on the other how well was it "repaired" at that time? That was exactly my thought process. I wouldn't have messed with those screws. 1 Share this post Link to post Share on other sites
Achto 30,166 #31 Posted December 6, 2023 11 hours ago, peter lena said: thought about , getting the bowl out of the shaft area 9 hours ago, WHX?? said: Bowl stays Greasy Pete I'm an original freak. Jim & I gets all sedimental bout those bowls. 2 4 Share this post Link to post Share on other sites
Achto 30,166 #32 Posted December 6, 2023 (edited) Why do double posts happen??? Edited December 6, 2023 by Achto Share this post Link to post Share on other sites
WHX?? 53,284 #33 Posted December 6, 2023 1 hour ago, ebinmaine said: Wish I could change text colors. from my phone. .... We just wished you would change yer under wear... 6 1 Share this post Link to post Share on other sites
ebinmaine 75,689 #34 Posted December 6, 2023 14 minutes ago, WHX?? said: We just wished you would change yer under wear... Unlikely 6 Share this post Link to post Share on other sites
Handy Don 15,133 #35 Posted December 6, 2023 2 hours ago, Achto said: Jim & I gets all sedimental bout those bowls. EXCELLENT! BRAVO! 1 1 Share this post Link to post Share on other sites
squonk 44,859 #36 Posted December 6, 2023 On 12/4/2023 at 8:13 PM, SylvanLakeWH said: I say try the seal. You've had good luck, know the drill, and can have @Achto do the work while you mix the drinks... er, manage... You know what they say: If you want it done right..... 2 2 Share this post Link to post Share on other sites
ebinmaine 75,689 #37 Posted December 6, 2023 3 minutes ago, squonk said: You know what they say: If you want it done right..... Have BBT do the work??? 1 5 Share this post Link to post Share on other sites
SylvanLakeWH 29,789 #38 Posted December 6, 2023 11 hours ago, WHX?? said: We just wished you would change yer under wear... 11 hours ago, ebinmaine said: Unlikely 1 hour ago, squonk said: You know what they say: If you want it done right..... Oh... my... eyes... Just have @Achto seal the tank and all three you guys change your own undies... please. 1 6 Share this post Link to post Share on other sites
WHX?? 53,284 #39 Posted December 6, 2023 17 hours ago, Achto said: Why do double posts happen??? You either double stroked it or short stroked it... 1 1 1 Share this post Link to post Share on other sites
WHX?? 53,284 #40 Posted December 13, 2023 (edited) Sealling came out well. 96 Hr cure time tho... talk about watching paint dry! Grey spot is sealer coming out around the leak. Amigo tank came out nice too... I hope.... Back on and plumbed. There's enough sealer in the kit to do a five gallon tank or so they say. Since these little gys just take a small amount so instead of letting it go hard in the can work bench got the rest. Dad always said... waste not want not.... Edited December 13, 2023 by WHX?? 3 4 Share this post Link to post Share on other sites
953 nut 62,975 #41 Posted December 14, 2023 8 hours ago, WHX?? said: work bench got the rest. Did it stop the work bench from leaking? 5 Share this post Link to post Share on other sites
SylvanLakeWH 29,789 #42 Posted December 14, 2023 8 hours ago, WHX?? said: work bench got the rest. Dad always said... waste not want not.... That there's a good idea and some good advice...! 2 1 Share this post Link to post Share on other sites
WHX?? 53,284 #43 Posted December 14, 2023 1 minute ago, 953 nut said: Did it stop the work bench from leaking? Not really Richard ... it leaked down below through drill holes. Woulda been a nicer job if I woulda belt sanded the 2xs first. Gotta find out with this stuff actually is. Some kind of urethane and woulda made for a nice durable bench top coating when done right. 1 1 1 Share this post Link to post Share on other sites
