RED-Z06 2,379 #1 Posted December 4, 2023 Ive heard so much good about the stuff being used in so many applications, it repels and doesn't emulsify with water, its a grease until it starts moving then its like a heavy oil.. Wonder if it would work in a unidrive? Share this post Link to post Share on other sites
ebinmaine 69,710 #2 Posted December 4, 2023 2 minutes ago, RED-Z06 said: grease until it starts moving then its like a heavy oil. Would it be capable of splash lubing upper gears that may not be in the oil bath? Share this post Link to post Share on other sites
peter lena 8,970 #3 Posted December 4, 2023 @RED-Z06 https://www.redpowermagazine.com/forums/topic/107709-corn-head-grease-in-haybine-gearbox/ JUST SNOOPIN AROUND , PETE Share this post Link to post Share on other sites
TonyToro Jr. 1,718 #5 Posted December 4, 2023 5 minutes ago, SylvanLakeWH said: always trying to find new oil/grease to use in the pulling tractors to creative less resistance as posible. Share this post Link to post Share on other sites
RED-Z06 2,379 #6 Posted December 4, 2023 1 hour ago, ebinmaine said: Would it be capable of splash lubing upper gears that may not be in the oil bath? Im not sure, it seems like its an excellent climbing lube for staying on gears, my only concern really is would it get the axle bearings. https://youtu.be/7zNhli-J0Gk?si=8CBXe-Cl3-AOmDLN 1 1 Share this post Link to post Share on other sites
squonk 41,939 #7 Posted December 4, 2023 I bet it would be a bear in cold weather. Let the clutch out and engine goes BLEAH! 4 Share this post Link to post Share on other sites
pfrederi 18,180 #8 Posted December 4, 2023 I use corn head in my Brush hog. It is a lot more expensive than good old 90w 1 Share this post Link to post Share on other sites
953 nut 56,742 #9 Posted December 5, 2023 Several years ago a fellow had a Unidrive with a plexiglass window in the top of it. It was operated by an electric motor and running rather slowly but the 90 weight gear oil was slinging all over the place. I would be afraid the Corn Head wouldn't get to the upper gears and the outer axle bearings. 3 1 Share this post Link to post Share on other sites
