peter lena 8,655 #1 Posted December 4, 2023 https://www.grainger.com/product/8A647?gucid=N:N:PS:Paid:GGL:CSM-2295:4P7A1P:20501231&gad_source=1&gclid=CjwKCAiAjrarBhAWEiwA2qWdCLJ7ngpI3l_NwP-iWi-OwSBFGOvCYw7k1fCCJkdO7Tx2c6QlUpLbeBoCogoQAvD_BwE&gclsrc=aw.ds often refer to poor rectifier , grounding , easy to make up a similar clip on ground cable , from battery ground bolt to rectifier , mount screw / bolts , lets you eliminate the cooling tin rust corrosion , cause , Pete Share this post Link to post Share on other sites
Racinbob 11,115 #2 Posted December 4, 2023 Jeez, that's pricy for a jumper. 1 Share this post Link to post Share on other sites
peter lena 8,655 #3 Posted December 4, 2023 @Racinbob have a few of these , in various wire connection grades . all made up in house , made as called for with chronic issues . also have stainless cable for other various uses , regularly , make up experimental anything for a repetitive issue . very good for a ground / quick connection verification. also have stainless grounding cables left over from working days . used them for glass piping , steel flange ground assurance , at gasket change over time , stay grounded , pete 1 Share this post Link to post Share on other sites
