MSBiker
Wheel Horse Lawn Ranger Repower with Kohler K181
MSBiker
Is it possible to repower a 1968 Lawn Ranger with a Kohler K181 without too much fanfare. My yard is very hilly and the extra couple horse power would be handy. Found a K181 for a reasonable price.
Pullstart
Hey there, it should work just fine.  I am not positive if the LR tractors had a Tecky on them, but my 502 originally did. The front tab for the belt guard to bolt to the engine doesn’t quite line up.  I used an 1/8” plate bolted to the engine and tapped it to fit the hole on the belt guard.  Some people have removed and rebuilt the tab however.
*edit* my 502 has a K181 now too.
Edited by Pullstart
Jon Paulsen
@dclarke nice looking tractor. Engine looks right at home in there. I dig it!
pfrederi
14 hours ago, dclarke said:
Mine has a K181 in it, it’s not hard to do.
How did you rig up the gas tank to align with the original hood hole.
dclarke
I cut the original tank bracket as needed then welded some flat steel to it so I could bolt it to the engine.
MSBiker
Thanks folks for the info! I might just go this route if I can get this engine fo cheap.
Mike'sHorseBarn
Mine has a k181 swap as well, totally doable though I bought it that way. An atv battery had to be used in place of a standard garden tractor battery though because of fitment issues.
MSBiker
Nice. Thanks.
Keaton
that looks awsome i have a k181 in my 856, big power, small tractor
