ebinmaine 70,700 #1 Posted December 1, 2023 Is there enough room inside the Wheelhorse Cab to operate the Angle Lever? Share this post Link to post Share on other sites
wallfish 17,485 #2 Posted December 1, 2023 Cab a blower tractor and suck it up for a plow tractor! LOL @Ed Kennell runs a cab with a plow tractor, I think 3 Share this post Link to post Share on other sites
ebinmaine 70,700 #3 Posted December 1, 2023 1 minute ago, wallfish said: Cab a blower tractor and suck it up for a plow tractor! LOL @Ed Kennell runs a cab with a plow tractor, I think This isn't for us. Trina and I don't use cabs. We are wondering, for the friends we're building a tractor for. Share this post Link to post Share on other sites
Ed Kennell 40,464 #4 Posted December 1, 2023 1 hour ago, ebinmaine said: Is there enough room inside the Wheelhorse Cab to operate the Angle Lever? Easy peasy if you add a few bends to the lever. Keeps my hands inside the warm cab. It is snug for this 180lb bear cub. May be kinda tight for a large Kodiak Bear. 3 1 Share this post Link to post Share on other sites
ebinmaine 70,700 #5 Posted December 1, 2023 1 minute ago, Ed Kennell said: Easy peasy if you add a few bends to the lever. Keeps my hands inside the warm cab. It is snug for this 180lb bear cub. May be kinda tight for a large Kodiak Bear. The guy that wants to know is taller than me but nowhere near my girth. I won't have time to modify a lever yet but maybe we can put that on the things to do list. Share this post Link to post Share on other sites
Ed Kennell 40,464 #6 Posted December 1, 2023 1 hour ago, ebinmaine said: The guy that wants to know is taller than me but nowhere near my girth. Probably be OK then. My foot control pedal linkage takes up some of the right leg room, but It works fine. I used some well placed small eye bolts as guides for the cable and a small turnbuckle for tension adjustment. The cable pull lever has to go on the other (bottom) side of the main lever. To make the bends, I just saw a small VEE notch in the lever leaving about 1/4" of metal to bend. Start small and increase the notch width till you cet the desired angles. After fitting to final shape, weld the notches closed. I also added a small scab plate to each bend for extra strength. 1 Share this post Link to post Share on other sites
Ed Kennell 40,464 #7 Posted December 1, 2023 I just noticed you were asking for a 300 series. My 54" plow with the altered lever and cab was on my 520H. I don't think there would be any difference in the size. I have actually removed this plow and installed the 2 stage blower. 1 Share this post Link to post Share on other sites
