peter lena 9,087 #1 Posted November 30, 2023 https://www.amazon.com/Boeray-Degree-Elbow-Fitting-Adapter/dp/B07DW6Y2FB/ref=pd_lpo_sccl_3/140-8047310-8767347?pd_rd_w=M2iDk&content-id=amzn1.sym.116f529c-aa4d-4763-b2b6-4d614ec7dc00&pf_rd_p=116f529c-aa4d-4763-b2b6- done a number of these , changing up to a 5/16 ID fuel hose was a simple easy carb issue improvement . what ever the issue , there is always another improvement spot , have these on both electric fuel pumps and original lever type , seamless upgrade . just my trials , Pete 1 1 Share this post Link to post Share on other sites
WHX?? 50,709 #2 Posted November 30, 2023 Thanks Pete. I often forget the jungle has fittings like that. My luck the bin at Ace is empty and can always use more than one. 1 Share this post Link to post Share on other sites
peter lena 9,087 #3 Posted November 30, 2023 @WHX?? no problem , another thing I do on the barb end is to slide on the squeeze hose clamp first away from installation hose area . also like a tiny swipe of dielectric grease , or super lube on the barb end , makes the fitting much easier , yet still making for a solid barb bite . then its easy to square nose plyer the spring hose clamp up to place . they also have that fitting in a straight version , just used some on an electric fuel pump upgrade , clear fuel vinyl line , Pete 1 Share this post Link to post Share on other sites
Achto 28,768 #4 Posted November 30, 2023 22 minutes ago, peter lena said: slide on the squeeze hose clamp Handy tool for squeeze type hose clamps. Gets in those hard to reach places. https://www.amazon.com/Clamp-Pliers-inches-Flexible-Cable/dp/B0917J3DBG/ref=sr_1_1_sspa?crid=3BYSF7XS8A9VO&keywords=hose%2Bclamp%2Bpliers&qid=1701371951&sprefix=hose%2Bclam%2Bpluers%2Caps%2C115&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1 3 1 Share this post Link to post Share on other sites
cafoose 3,383 #5 Posted November 30, 2023 3 hours ago, Achto said: Handy tool for squeeze type hose clamps. Gets in those hard to reach places. https://www.amazon.com/Clamp-Pliers-inches-Flexible-Cable/dp/B0917J3DBG/ref=sr_1_1_sspa?crid=3BYSF7XS8A9VO&keywords=hose%2Bclamp%2Bpliers&qid=1701371951&sprefix=hose%2Bclam%2Bpluers%2Caps%2C115&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1 Thanks @Achto just ordered one 1 Share this post Link to post Share on other sites
squonk 42,519 #6 Posted December 1, 2023 High grade rubber fuel hose and stainless steel clamps for me. None of that "get brittle in a year" vinyl hose / spring clamp and gas leaking in the garage! 2 Share this post Link to post Share on other sites
WHX?? 50,709 #7 Posted December 1, 2023 I use those spring clamps religiously Squonky and never have a leak. Those cheap jungle filters now a different story. Share this post Link to post Share on other sites
peter lena 9,087 #8 Posted December 1, 2023 @WHX?? found the dark green , 5/16 spring clamp is spot on , colors on that type of clamp , verifies size / fit , leave the clamp out of the way while mounting the set up , detail fit , squeeze / slide clamp into place . no leaks / problems , always bring a small piece of hose along , when clamp shopping, verify fit , good talking , Pete 1 Share this post Link to post Share on other sites
squonk 42,519 #9 Posted December 1, 2023 1 hour ago, WHX?? said: I use those spring clamps religiously Squonky and never have a leak. Those cheap jungle filters now a different story. I have seen those clamps break as well as the vinyl hoses crack and fall off. Maybe I'm too sensitive but in my Napa days 3 customers lost shops due to gas lines dripping and starting a fire. Share this post Link to post Share on other sites
peter lena 9,087 #10 Posted December 1, 2023 @WHX?? since putting STA BIL in every bit of my , fuel related anything have zero debris in filters , at my change over time , from tank forward its all clean , the additive does not break down hoses . that goes for , stand by generator and walking snow blower . if you have a fuel / grunge problem , don't expect any additive to suddenly eliminate the issue . clean out the crap / grunge , then add STA BIL to all your fuel . filter close to tank , clean , filter close to carb clean , no leaks or hose break down . years now , this must work . Share this post Link to post Share on other sites
