JoeM
Using inline filter on gravity feed systems
JoeM
Was working on a project the other day and installed a Kohler fuel filter on an inline gravity feed system. The filter was rated at 75 micron and it really restricted the flow. I have not had any issue with these in the past on gravity feed but those tanks were a bit higher. Ended up using a Briggs 150 to solve the starvation issue.
Anyone got a better filter suggestion?
Achto
Don't know if it's better, but another alternative.
I have started to switch over to Raider fuel filters normally made for snowmobiles. No paper or cloth filter inside, just a fine screen. Microns / Shmicrons, if it's small enough to go through the fine screen it won't hurt the engine anyway. :twocents-twocents: Most factory fuel systems only relied on a fine screen.
https://www.tractorsupply.com/tsc/product/raider-in-line-fuel-filter-1144179?cid=Shopping-Google-Product-1144179&gad_source=1&gclid=EAIaIQobChMI4c_wjrjkggMVqczCBB3AOgBkEAQYAyABEgKOfPD_BwE
  • Like 4
Sparky
Shmicrons :lol: !
  Agree! Our WH’s only had that screen in the tank shutoff from the factory.
  • Haha 2
pfrederi
Been using the B&S 150 on my L107 for many years
stegs
i order these from amazon
They work great, never any fuel starvation issues. Do a great job catching crap in the fuel lines and they are clear so you can see how dirty the cloth is getting
https://www.amazon.com/Cococart-Inline-Filters-Kawasaki-Stratton/dp/B06XDJR2JT/ref=sr_1_3_pp?crid=19UW535F57BIZ&keywords=inline+fuel+filter&qid=1701099114&sprefix=inline+fuel+filter%2Caps%2C117&sr=8-3
Pullstart
Call me old fashioned, but I’ve never had a filter issue with one of these…
D_Mac
Leaking issue with those sediment bowls. I removed all mine.
pfrederi
They are not as easy to use. Bowl gaskets can harden and make sealing difficult. The packing on the shut offs seems to need periodic tightening and you still have to clean the fine screening.  Have them on my big tractors that is enough work none on the WHs
ri702bill
3 hours ago, Sparky said:
Shmicrons :lol: !
The oh-so-fine screen tube in the shut-off does plug up from time to time. I have no screen in the non-original shutoff on the 854 - just a 1/4" inline clear filter.... no issues.
Edited by ri702bill
Jon Paulsen
Back in the day, I used something like this. IIRC they came with a few replacement elements. Nothing got through that was large enough to clog a main jet. 3/8" Inline Fuel Filter Clear View Glass Reusable Washable For Motorcycle Car - Picture 7 of 7
  • Like 5
JoeM
those raiders look like the ticket
ebinmaine
What's with the low reviews?
Horse Newbie
Old fashioned…
  • Haha 4
JoeM
I see they say the hose size is larger than advertised . There was only 5 reviews tho.
ebinmaine
I've seen that happen too.
Likely a metric piece sold as the incorrect American measure equivalent.
squonk
I've had multiple issues with that style filter airlocking
Achto
I would have to agree with this. They say 3/16" to 1/4" fuel line. It would be more correct to say 1/4" to 5/16" fuel line. A 1/4" fuel line still fits on them with a little extra effort.
One other plus to these screen type filters is that you can back flush them to clean them out if need be.
Edited by Achto
  • Like 4
stegs
really? I never have. I have them on my golf cart, zero turn mower, and all of my wheel horse tractors. Never once had a issues with them. I find for 1 dollar each, they are great filters, flow plenty of fuel and still do a great job filtering the fuel
RED-Z06
75mic really shouldn't be a problem, but a 150mic should be good enough to keep the majority of stuff out.  I use Fram G12 which is 10micron, on pretty much everything i own, but everything has fuel pumps of some kind vs gravity.
peter lena
@Achto  agree wit you on the fuel hose issue , all of my stuff is changed over to 5/16 , fuel line , also verified tank cap venting , is vital . lots of hose connection fittings at local / H/W  slide out drawer section /  changed out that  problematic  area , long ago . when ever I get told you can't do that  , really ? love removing a chronic issue , over the fence , pete
Wheelhorse#1
Been using these for a wile now.150 micron supposedly.
Cheap & No issues
RED-Z06
Cheap & No issues
These are good at stopping the big stuff, same basic mesh as the old glass bowl filters, and the filters on the in-tank pickups on 300/400/500 series.
