Joe leonardo 164 #1 Posted November 26, 2023 I got the s/g in and have no clue about the wiring Share this post Link to post Share on other sites
ri702bill 8,316 #2 Posted November 26, 2023 Download your tractor model manual - wiring diagram near the end... Share this post Link to post Share on other sites
J854D 137 #3 Posted November 26, 2023 @Joe leonardo, is this starter/generator off of the same tractor as the 1969 Charger 12 identified in one of your earlier posts from today? If it is, a 69 Charger originally doesn’t have a starter/generator system. Which may indicate there has been an engine change. At any rate, the s/g wiring is fairly straight forward. The voltage regulator on top of the s/g will have 3 terminals out front and one underneath it. The terminals out front are stamped; L, BAT, & F. The L term. is for any electrical load you have like lights or a cigarette lighter. The BAT term. goes to the ammeter (if equipped) or to a positive + battery source, (sometimes at the ignition switch) The F term. connects to the F terminal on the generator. The generator has two terminals on it with one stamped F next to it & the other stamped A next to it. The A terminal on the generator connects, with a small wire, to the terminal underneath the regulator. The A terminal on the generator also has a heavier wire attached to it that goes to the ignition switch or a push button switch used for starting. The s/g also needs a good negative - frame ground for everything to work properly. -JD- Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,040 #4 Posted November 26, 2023 Click on the fuzzy part below 2 1 Share this post Link to post Share on other sites
peter lena 8,611 #5 Posted November 27, 2023 @ s/g wiring , https://www.google.com/search?q=wire+cable+wrap&rlz=1C1CHBF_enUS866US866&oq=WIRE+CABLE+WR&gs_lcrp=EgZjaHJvbWUqBwgAEAAYgAQyBwgAEAAYgAQyBggBEEUYOTIICAIQABgWGB4yCAgDEAAYFhgeMgoIBBAAGA8YFhgeMggIBRAAGBYYHjIGCAYQRRg9MgYIBxBFGEGoAgCwAgA&sourceid=chrome&ie=UTF-8 as you lay out new wiring , eliminate tight / chafing areas , use cable wrap and screw on eyelets , to secure your work , also use dielectric grease , on screw threading , connections , check and verify as you go , Pete Share this post Link to post Share on other sites
953 nut 55,194 #6 Posted November 28, 2023 On 11/26/2023 at 3:44 PM, Joe leonardo said: got the s/g in and have no clue about the wiring I posted in another of your threads that you fist need to let us know what ignition switch you have. If it is the one pictured below then this diagram will work. Share this post Link to post Share on other sites
