JoeM 9,317 #1 Posted November 26, 2023 Daughter says my leaf blower doesn't run. Tell me more. Well, I put the wrong gas in with no mix. Oh...... how long did you run it. (typical answer) until it stopped. So anyway the last one I had taken the carb and exhaust off and sprayed with WD40 and got the rings loose again. So I figured this time I would just spray WD in the carb and pull the rope off and on. After a couple hours of putting in the WD, while I worked on other stuff, it seemed like there was some compression. Gave it a shot of start juice and it fired up. Smoked like a forest fire. The longer it ran the better. And it came around. I figure the WD just lubricated the rings enough to let go of the piston. I would call it a save. 5 3 Share this post Link to post Share on other sites
CCW 1,454 #2 Posted November 26, 2023 Sounds that way to me. Share this post Link to post Share on other sites
sjoemie himself 3,106 #3 Posted November 28, 2023 On 11/26/2023 at 4:44 PM, JoeM said: I would call it a save. Sure sounds like it, until it stops again anyways Share this post Link to post Share on other sites
Handy Don 15,176 #4 Posted November 30, 2023 On 11/26/2023 at 10:44 AM, JoeM said: how long did you run it. (typical answer) until it stopped. A few weeks ago had the same experience. A non-profit that I help with their outdoor equipment called--string trimmer stall. User didn’t know about mix gas. I got it going after some extra lube down the plug hole. Surprisingly little smoke and it ran well. Whew. Last week another call. The trimmer stopped again. Same user. I suggested that person not be allowed near mechanical stuff without supervision. Tomorrow I’ll see if I can resurrect the trimmer or if it will need a major overhaul. 3 Share this post Link to post Share on other sites
JoeM 9,317 #5 Posted November 30, 2023 9 hours ago, Handy Don said: I’ll see if I can resurrect the trimmer Don I had one last year with the same issue and had to remove the muffler so I could pic at the rings a bit. It has ran fine after loosing up the rings. I would say there is hope. 1 Share this post Link to post Share on other sites
