RJR49 129 #26 Posted January 4 I used a 4X4 and the front end weight of an F-350 Super Duty to break the bead on a Corvette rear tire. Barely enough weight if you can believe that. A Wheel Horse tire should be much easier. But, that just breaks the bead. getting the tire off is a different story. Also there is a YouTube video showing how to break the bead with a floor jack. 1 Share this post Link to post Share on other sites
OoPEZoO 525 #27 Posted January 4 I've changed 100's of tires over the years using that larger HF tire changer posted earlier. Car tires, motorcycle tires, tractor tires, wheelbarrow, trailer........I've never had a bead I couldn't break with it. The trick to removing and installing the tires with the HF setup is to take the included large mount/dismount bar and throw it in the trash. Do a google search for the Mojolever. Its a little side hustle my motorcycle buddy Mitch has been up to for the past 15+ years. I've been using mine since probably 2006ish and couldn't be happier. I did have to have him send me a new dismount tip at one point when I attempted to remove some 1940's original Jeep tires and bent the mounting bolt, but other than that its been a fantastic addition to the garage. I just swapped the tires on my 522xi over the holidays and the mount/dismount part of the dance only took me maybe 20mins total for all 4 tires........and that included adding tubes, working by myself, and without the changer bolted down. Bolting it down and/or having a 2nd set of hands makes it a breeze. 3 Share this post Link to post Share on other sites
Lee1977 6,669 #28 Posted January 5 4 hours ago, RJR49 said: I used a 4X4 and the front end weight of an F-350 Super Duty to break the bead on a Corvette rear tire. Barely enough weight if you can believe that. A Wheel Horse tire should be much easier. But, that just breaks the bead. getting the tire off is a different story. Also there is a YouTube video showing how to break the bead with a floor jack. A really rusted on 2 ply tire weight don't help the tire just folds straight down. They are not stiff enough to pull it lose. 2 Share this post Link to post Share on other sites
David Blanchard 9 #29 Posted January 8 push the bead down far as you can and pour some gas into it. let it sit awhile and try it again repeat if necesary 1 Share this post Link to post Share on other sites
953 nut 55,322 #30 Posted January 8 On 1/4/2024 at 8:56 PM, Lee1977 said: A really rusted on 2 ply tire weight don't help the tire just folds straight down. They are not stiff enough to pull it lose. Have a couple pounds of air pressure in the tire to keep the sidewall from folding under, make up some small wooden wedges and place a wedge on each side of the jack after it has gone as far as it will. Once this is done rotate the tire a quarter turn and repeat the process. If the rim and tire are rusted together a bit of penetrating oil can be placed in the opening between the tire and rim and allowed to soak. Share this post Link to post Share on other sites
Lee1977 6,669 #31 Posted January 8 (edited) On 1/7/2024 at 8:15 PM, David Blanchard said: push the bead down far as you can and pour some gas into it. let it sit awhile and try it again repeat if necesary That might work if I set it on fire. . I'm not too fond of two ply tires, but I can't cut them off. I'm trying to save the tubes they are better they any I can buy.\ They are off took way too long to save the tubes. Edited January 9 by Lee1977 Share this post Link to post Share on other sites
Retired Wrencher 5,465 #32 Posted January 9 (edited) On 11/24/2023 at 4:46 PM, ebinmaine said: Sometimes you can break the bead by driving up on the edge of the tire beside the rim with a heavy vehicle. If you're not trying to save the tire a sawzall is your friend. If you are trying to save the tire a manual tire changer from HF will be your friend. Eric I have had mixed results with H/F tier changer by breaking the bead. The bead breaker is not heavy duty enough on the big 23” Just my I also you big spoons once the bed is broke. That make it easy. Edited January 9 by Retired Wrencher 1 Share this post Link to post Share on other sites
