Joe leonardo 164 #1 Posted November 24, 2023 I have a charger 12 and wanna make it to quicker 1 Share this post Link to post Share on other sites
ebinmaine 67,515 #2 Posted November 24, 2023 Hydros really are limited. You can increase the tire size but that leads into a whole new world of modifications. 2 Share this post Link to post Share on other sites
Joe leonardo 164 #3 Posted November 24, 2023 13 minutes ago, ebinmaine said: Hydros really are limited. You can increase the tire size but that leads into a whole new world of modifications. Darn 1 Share this post Link to post Share on other sites
WheelHorseEnjoyer 25 #4 Posted November 24, 2023 The best thing to do would be to get rid of the hydro, put the manual in it and make it a Raider 12. 1 2 Share this post Link to post Share on other sites
Pullstart 62,896 #5 Posted November 24, 2023 May I suggest, keeping all your posts on this new machine in one thread? It’ll help paint the whole picture when we’re working to help you get to the ultimate goal - putting around with a grin on your face! With that said, the guys above are spot on. Not much you can do to over drive a hydro, but to see the limitations of these machines, check @Skipper’s big hydro thread out! 2 1 Share this post Link to post Share on other sites
JoeM 7,874 #6 Posted November 24, 2023 Is faster as in not up to par or you want a hot rod? 1 Share this post Link to post Share on other sites
953 nut 55,246 #7 Posted November 24, 2023 1 hour ago, JoeM said: Is faster as in not up to par or you want a hot rod? 3 hours ago, Pullstart said: May I suggest, keeping all your posts on this new machine in one thread? It’ll help paint the whole picture when we’re working to help you get to the ultimate goal - If the transaxle is sluggish there could be some weak or broken springs on your acceleration valves or a pump that needs to be rebuilt. If you are wanting to hot rod it then larger diameter tires are all that is needed. One thing to keep in mind while seeking a solution to your need for speed is the potential damage you could do to the transaxle. The Sundstrand transaxle has no brakes other than the transmission so the faster you go the more internal stresses are put on internal parts when stopping. 3 Share this post Link to post Share on other sites
Sailman 1,291 #8 Posted November 24, 2023 If you are hot rodding I can't help but if the unit is "sluggish" especially when hot try switching to 10w40 oil in the transmission. Really fixed the issue in my C-120 doing that. If you have ATF fluid instead then this is not a good option. 1 Share this post Link to post Share on other sites
pfrederi 17,739 #9 Posted November 24, 2023 Charger 12 is one of the fastest WHs 7.0 mph faster than the gear drives... a GT14 is a bit faster at 7.5 probably result of larger tires/wheels 2 Share this post Link to post Share on other sites
RJR49 129 #10 Posted December 9, 2023 Put a smaller pulley on the pump Share this post Link to post Share on other sites
RJR49 129 #11 Posted December 9, 2023 You would probably need a smaller belt too but it wouldn't be complicated. Share this post Link to post Share on other sites
ebinmaine 67,515 #12 Posted December 9, 2023 Just now, RJR49 said: Put a smaller pulley on the pump Have you successfully done this? My understanding is that the hydro pump is limited to a certain amount of fluid movement thereby keeping the speed down. Share this post Link to post Share on other sites
RJR49 129 #13 Posted December 9, 2023 I did it on my snowblower. At nearly 50 years old (1975 C-160) I think putting more stress on the hydro is asking for trouble. If there is a restrictor in the system I suppose you could remove it, or enlarge it. But again do you really want to stress a mechanical devise that old? 1 Share this post Link to post Share on other sites
Handy Don 12,232 #14 Posted December 9, 2023 (edited) 13 minutes ago, RJR49 said: Put a smaller pulley on the pump Yes, you can turn the pump faster, but you’ll be exceeding the clearly labeled specifications. Extra heat and possibly cavitation may cause internal damage. Find a 520-HC -- they had higher geared rear ends and went 9+ mph stock. Edited December 9, 2023 by Handy Don 1 Share this post Link to post Share on other sites
ebinmaine 67,515 #15 Posted December 9, 2023 2 minutes ago, RJR49 said: I did it on my snowblower. At nearly 50 years old (1975 C-160) I think putting more stress on the hydro is asking for trouble. If there is a restrictor in the system I suppose you could remove it, or enlarge it. But again do you really want to stress a mechanical devise that old? Not me, no. Just curious..... I'm the other way around in fact. Share this post Link to post Share on other sites
