Joe leonardo
Is this a wheel horse?
wallfish
1 hour ago, Joe leonardo said:
It would be hard to teach kids with them not being able to hear me any ideas on how I can coach them and teach them?
It had the best option for that to begin with. Scrap the stack idea (I don't like them anyway) and put that big muffler and exhaust pipe back on. Being it was located down below would be the ideal solution for this.
Certainly not the best location for rough terrain working but I'd suppose the little kids won't be off roading when they're learning anyway. :twocents-02cents:
Handy Don
Ear protection reduces but does not eliminate sound. Most of the good ones also are engineered to pass through more of the frequencies of the human voice than other frequencies (Shooter-style protectors are an exception). I can hear someone speak to me while protected with no issues--yes, with slightly raised voice but over tractor noise you’d have to shout anyway.
I’m in agreement with putting on the quietest muffler you can find AND using ear protection :)
  • Like 4
Joe leonardo
Long time no see but I finally got the tractor restored, I'm a big chrome stack snob and have always liked the look so I put one on and wrapped it with exhaust wrap. I got the new stickers on it and all painted up, completely rewired it. the thing had been sitting in the back of the school shop sense January and I finally got around to getting it back together I don't really know what I'm gonna do when I graduate next month but maybe it will be my family heirloom or I can tote around a little trailer
  • Excellent 7
Moparfanforever
Looks sharp!!!
:thumbs:
8ntruck
On 1/27/2024 at 11:18 AM, Handy Don said:
Gonna strongly suggest an immediate investment in ear protection for your young charges, regardless of your exhaust setup decision. Get them started early (and get some for yourself at the same time). If you were coaching a sport, you’d insist on proper equipment. Same here.
After decades of unprotected use of power equipment, my hearing has been noticeably affected and I’ve “heard" from other members with the same issue. I wish someone had given me a heads up on this many years ago.
Strongly agree here (hear?).  Hearing loss is cumulative - damage does not entirely heal.
Joe leonardo
Yeah we didn't end up letting them drive the mower
Joe leonardo
So it has stopped going forward and backward it's has oil in it and this really really sucks what could be the problem?
Ed Kennell
Is the tow valve closed?
Joe leonardo
No it's open
Ed Kennell
43 minutes ago, Joe leonardo said:
No it's open
This valve must be closed to run.
Joe leonardo
Er sorry yeah it's closed still no movement
Ed Kennell
Is the belt tensioner in gear and is the transmission pulley turning.  Is the shaft inside the pulley turning or is the pulley slipping on the shaft?
Joe leonardo
Yeah the pulley is spinning
Joe leonardo
Posted (edited)
I was going along and it stopped I backed it up a foot and then completely stopped moving it was on a hill
Edited by Joe leonardo
Ed Kennell
Did you verify the shaft is turning?   It could also be either axle is spinning inside a hub.    If you are sure the punp shaft is actually turning and the axles are not turning, then check the linkages to be sure the transmission motion valve is moving.
Joe leonardo
I've checked everything it's all good I'm gonna change the fluid but before I get too ahead of myself, how should I check to see if the pump itself is bad
Ed Kennell
I have never done it, but there may be a procedure to check the pump pressure and to look for broken springs.
    Transmission Hydro Sundstrand SM #492-4206.pdf - Automatic / Hydro - RedSquare Wheel Horse Forum
Joe leonardo
I put new fluid in it and it still didn't move and then all the sudden the linkage jammed up
Ed Kennell
Well, maybe you have found the problem.  Could be the linkage was never moving the  sliding block that operates the motion valve.
Lane Ranger
I had one that had a parking prawl at the back of the inside of the transmission case that was a problem.   I recall it was bent and had to be reconfigured.  The transmission also had an axle needle bearing out - broken needles inside.   I replaced the bearing and I am still amazed how clean that hydro transmission was inside.
Joe leonardo
It was I had the cover off the whole time and was watching it then it locked up
Joe leonardo
I don't have a park break
Ed Kennell
Hmmm, all the Sundstrands I had came with the internal parking brake pawl that was usually broken.
Joe leonardo
How do I get to it
Lane Ranger
Posted (edited)
You tractor and your transmission did have when new.
it looks like you have a Charger 12.
check out this manual on a 1969 Charger 12.
?do=download&r=52892&confirm=1&t=1&csrfK
It will give you a lot more details about your tractor, parts , transmission, etc than we can give in any brief comments.
There is a very clear picture in this Charger 12 Manual showing the Parking Brake Handle that regulates the parking prawl in the transmission.
Edited by Lane Ranger
