hotajax 223 #1 Posted November 16, 2023 Where does it come from? I've spliced it so many times it needs to be replaced. Might be 12 ga wire. Thanks in advance. Share this post Link to post Share on other sites
Achto 27,641 #2 Posted November 16, 2023 10 hours ago, hotajax said: Where does it come from? What model tractor? Share this post Link to post Share on other sites
953 nut 55,394 #3 Posted November 16, 2023 The wire to your headlights should run from the light switch to the lights. sixteen gauge wire should be able to handle headlights, be sure it is mounted in a manner that will protect the wire from being pinched or having the insulation damaged. The wire that feeds the light switch should have a fuse in the line to protect the wire in the event of a short circuit. 2 Share this post Link to post Share on other sites
