Handy Don 12,214 #26 Posted November 10, 2023 16 hours ago, Achto said: drill a new hole through the bolt I’m wondering about two things: - getting the newly-drilled hole straight and in the right place - the heat of cutting off the extra part of the Allen screw could soften the Locktite and cause the screw to shift 2 Share this post Link to post Share on other sites
Achto 27,565 #27 Posted November 10, 2023 7 minutes ago, Handy Don said: the heat of cutting off the extra part of the Allen screw could soften the Locktite and cause the screw to shift Working temp of Loctite 640 sleeve retainer is 400F. Should be ok if one takes their time cutting. Maybe Sawzall first, then smooth out with a grinder. 5 Share this post Link to post Share on other sites
Retired Wrencher 5,451 #28 Posted November 10, 2023 6 hours ago, ebinmaine said: I've got some here too. But I'd like to see what you use. I take some picks tomorrow bud. I was gone all day to an old friend house. 2 Share this post Link to post Share on other sites
gt14rider 753 #29 Posted November 10, 2023 What about 2 part epoxy putty. You can drill and tap it. Here's one kind, but there's a bunch different manufacturers. 2 Share this post Link to post Share on other sites
ebinmaine 67,436 #30 Posted November 10, 2023 2 hours ago, Handy Don said: I’m wondering about two things: Me too. 2 hours ago, Handy Don said: - getting the newly-drilled hole straight and in the right place I could measure carefully following another case for pattern. 2 hours ago, Handy Don said: - the heat of cutting off the extra part of the Allen screw could soften the Locktite and cause the screw to shift 2 hours ago, Achto said: Working temp of Loctite 640 sleeve retainer is 400F. Should be ok if one takes their time cutting. Maybe Sawzall first, then smooth out with a grinder. Mobile bandsaw. ? 3 Share this post Link to post Share on other sites
Achto 27,565 #31 Posted November 10, 2023 37 minutes ago, ebinmaine said: Mobile bandsaw. ? Perfect!! 4 Share this post Link to post Share on other sites
Handy Don 12,214 #32 Posted November 10, 2023 1 hour ago, ebinmaine said: Me too. I could measure carefully following another case for pattern. Mobile bandsaw. ? Be sure it’s a standard grade screw! 2 1 Share this post Link to post Share on other sites
Pullstart 62,838 #33 Posted November 10, 2023 I bet a center punch, steady hand (or drill press) and going slow, most anyone could get it centered so the dog point screw can do it’s thing. 3 Share this post Link to post Share on other sites
ebinmaine 67,436 #34 Posted November 10, 2023 21 minutes ago, Pullstart said: I bet a center punch, steady hand (or drill press) and going slow, most anyone could get it centered so the dog point screw can do it’s thing. I do NEED to get my drill press chuck centering better. That's a subject for another thread. As to this one though... I'm thinking I could put a 1/4-20 bolt in a good transmission case. Use that to center and line up the transmission to the drill press by locking the good bolt in the drill press chuck. Loosen the assembly and lower it. Switch transmission cases and drill this one straight. Maybe???? 1 Share this post Link to post Share on other sites
Handy Don 12,214 #35 Posted November 10, 2023 12 minutes ago, ebinmaine said: I do NEED to get my drill press chuck centering better. That's a subject for another thread. As to this one though... I'm thinking I could put a 1/4-20 bolt in a good transmission case. Use that to center and line up the transmission to the drill press by locking the good bolt in the drill press chuck. Loosen the assembly and lower it. Switch transmission cases and drill this one straight. Maybe???? I'd be inclined more toward fabbing up a jig. Get it correctly positioned using a long screw through the jig into the hole on the good case with bends or adjusting screws and then move it to the to-be-drilled case. A fat dowel in the shifter hole could be main position/anchor. Also, I tend to drill small pilot holes first and follow up with the full-size bit. Good luck! 1 Share this post Link to post Share on other sites
WHX?? 48,815 #36 Posted November 10, 2023 3 hours ago, gt14rider said: What about 2 part epoxy putty. You can drill and tap it. I tried that stuff once. Called liquid steel. Didn’t work too hot. Drilled & tapped OK but didn't stick very well. Might not have it clean enough. Oil in metal pores? Share this post Link to post Share on other sites
Achto 27,565 #37 Posted November 10, 2023 55 minutes ago, ebinmaine said: As to this one though... I'm thinking I could put a 1/4-20 bolt in a good transmission case. Use that to center and line up the transmission to the drill press by locking the good bolt in the drill press chuck. This would be the beauty of using an Allen bolt. You already have a guide to find the center of the bolt. Run a drill bit that just fits inside of the hex head down a little bit to mark center. Then switch to the size bit that you need for the tap. Share this post Link to post Share on other sites
ebinmaine 67,436 #38 Posted November 10, 2023 38 minutes ago, Achto said: This would be the beauty of using an Allen bolt. You already have a guide to find the center of the bolt. Run a drill bit that just fits inside of the hex head down a little bit to mark center. Then switch to the size bit that you need for the tap. So if you're using the center of the Allen head that means you'd be removing the existing bolt redrilling and resizing the hole well oversized so it's back to straight? Share this post Link to post Share on other sites
Pullstart 62,838 #39 Posted November 11, 2023 Maybe it’s just me, I think we are way over thinking this. Figure the depth from the top surface, center the bit to the large opening with an eyecrometer, drill away. 4 1 Share this post Link to post Share on other sites
ebinmaine 67,436 #40 Posted November 11, 2023 1 hour ago, Pullstart said: Maybe it’s just me, I think we are way over thinking this. Figure the depth from the top surface, center the bit to the large opening with an eyecrometer, drill away. My own eyecrometer ain't that accurate. Also, doesn't the shifter have to be pretty close to lined up to keep the geometry right? 1 Share this post Link to post Share on other sites
JoeM 7,873 #41 Posted November 11, 2023 11 hours ago, ebinmaine said: My own eyecrometer ain't that accurate. Come on EB, go get BBT! 2 Share this post Link to post Share on other sites
ebinmaine 67,436 #42 Posted November 11, 2023 19 minutes ago, JoeM said: Come on EB, go get BBT! I often do!! 2 Share this post Link to post Share on other sites
Horse Newbie 7,069 #43 Posted November 12, 2023 22 hours ago, ebinmaine said: Also, doesn't the shifter have to be pretty close to lined up to keep the geometry right? I’m thinking pretty close will do… just my worth… 1 Share this post Link to post Share on other sites
ebinmaine 67,436 #44 Posted November 12, 2023 12 hours ago, Horse Newbie said: I’m thinking PRETTY CLOSE will do… just my worth… Agreed. That's why I phrased it as such. I'm thinking if I was within 3 widths of an outhouse either direction it'd work. 1 Share this post Link to post Share on other sites
