ebinmaine 69,710 #1 Posted November 9, 2023 @admin This is a transmission case but it's a general everyday situation. Feel free to move as necessary. I have a transmission case here that someone in the past has installed a VERY crooked shifter holder. What do I need to do to fix this? Here's a closely cropped pic showing the angle as best I can. My thought is to remove the bolt and drill out the hole. Fill it with JB Weld. Redrill and tap to correct size. Yes no? Thoughts comments questions suggestions welcome. Thanks!! 2 1 Share this post Link to post Share on other sites
John2189 476 #2 Posted November 9, 2023 Does it not hold or work the way it is? 3 Share this post Link to post Share on other sites
ebinmaine 69,710 #3 Posted November 9, 2023 13 minutes ago, John2189 said: Does it not hold or work the way it is? The point isn't quite centered. 1 Share this post Link to post Share on other sites
Jon Paulsen 291 #4 Posted November 9, 2023 Drill, tap, use next size up bolt? 6 Share this post Link to post Share on other sites
ebinmaine 69,710 #5 Posted November 9, 2023 4 minutes ago, Jon Paulsen said: Drill, tap, use next size up bolt? It's already WAY oversized. That's why I was thinking more like fill and start over. 2 Share this post Link to post Share on other sites
wallfish 17,193 #6 Posted November 9, 2023 (edited) JB Weld won't hold threads very well How about threaded inserts/rivets? Very handy tool to have around and many useful places to use them. Heliciol insert maybe? Yes the hole may need to be bigger but now you can down size the dogpoint https://www.amazon.com/s?k=rivet+threaded&adgrpid=1339205735366040&hvadid=83700598720095&hvbmt=be&hvdev=c&hvlocphy=51385&hvnetw=o&hvqmt=e&hvtargid=kwd-83700723113539%3Aloc-190&hydadcr=5102_13196128&tag=mh0b-20&ref=pd_sl_yeaorb6x7_e https://www.amazon.com/s?k=helicoil+kit&crid=1SFGGY4MW8ES7&sprefix=helicoil%2Caps%2C103&ref=nb_sb_ss_ts-doa-p_1_8 Edited November 9, 2023 by wallfish 4 1 Share this post Link to post Share on other sites
WHX?? 49,919 #7 Posted November 9, 2023 Helicoils? Not sure if you can stack them. 1 Share this post Link to post Share on other sites
ebinmaine 69,710 #8 Posted November 9, 2023 6 minutes ago, wallfish said: JB Weld won't hold threads very well How about threaded inserts/rivets? Very handy tool to have around and many useful places to use them. Heliciol insert maybe? Yes the hole may need to be bigger but now you can down size the dogpoint https://www.amazon.com/s?k=rivet+threaded&adgrpid=1339205735366040&hvadid=83700598720095&hvbmt=be&hvdev=c&hvlocphy=51385&hvnetw=o&hvqmt=e&hvtargid=kwd-83700723113539%3Aloc-190&hydadcr=5102_13196128&tag=mh0b-20&ref=pd_sl_yeaorb6x7_e https://www.amazon.com/s?k=helicoil+kit&crid=1SFGGY4MW8ES7&sprefix=helicoil%2Caps%2C103&ref=nb_sb_ss_ts-doa-p_1_8 Just now, WHX?? said: Helicoils? Not sure if you can stack them. I'm seeing the idea here. I'd have to go REALLY big though. The bolt is already too big. And crooked. Is there a different compound/product/repair product I could use or do? I wouldn't be very likely to pay to get it repaired because a good used case would be cheaper. That said, this is a low hours unit with great gears and if like to save it. 1 Share this post Link to post Share on other sites
953 nut 56,742 #9 Posted November 9, 2023 My suggestion would be to silver solder (hard solder) the hole to a slightly smaller size, drill it out to 13/64" and tap to 1/4-20. The threads don't have to withstand a great deal of force so the silver solder threads will hold fine. 6 2 1 Share this post Link to post Share on other sites
wallfish 17,193 #10 Posted November 9, 2023 (edited) 8 minutes ago, ebinmaine said: I'd have to go REALLY big though. 3/8 hole for a 1/4-20 Cover it with a shift boot and you will be the only one that knows about it. Looks like it might a 3/8 hole in there now You can try just running a tap through it but keep it straight Some threads may be boogered but not like it's holding something supper hard. Maybe JB Weld could be used just to fill in some of the missing gaps in the threads. IDK if it's even necessary Edited November 9, 2023 by wallfish 2 Share this post Link to post Share on other sites
ebinmaine 69,710 #11 Posted November 9, 2023 4 minutes ago, wallfish said: 3/8 hole for a 1/4-20 Cover it with a shift boot and you will be the only one that knows about it. You can try just running a tap through it but keep it straight Some threads may be boogered but not like it's holding something supper hard. Maybe JB Weld could be used just to fill in some of the missing gaps in the threads. IDK if it's even necessary I'd have to measure the current bolt. It's already ⅜ I'll bet. 1 Share this post Link to post Share on other sites
Achto 28,190 #12 Posted November 9, 2023 21 minutes ago, WHX?? said: Helicoils? Not sure if you can stack them. Probably not ideal to stack them, they do make them in different lengths though. 3 Share this post Link to post Share on other sites
Horse Newbie 7,168 #13 Posted November 10, 2023 31 minutes ago, WHX?? said: Helicoils? Not sure if you can stack them. Yes, you can stack them. I was thinking I have done it before, according to their own instructions… 1 Share this post Link to post Share on other sites
Achto 28,190 #14 Posted November 10, 2023 11 minutes ago, ebinmaine said: I'd have to measure the current bolt. It's already ⅜ I'll bet. if the hole is already 3/8", a Helicoil would not work. Here is one idea. Thread a grade 5 or less 3/8" allen bolt into the hole and tighten it down. Use some green Loctite sleeve retainer to make sure it is a permanent fixture. Let it dry over night. I suggest an allen bolt because I don't think there will be enough room to tighten down a 9/16" head on a regular bolt. After the Loctite has dried drill a new hole through the bolt and tap it 1/4-20. After you tap the hole, grind the head off from the allen bolt. Should be a permanent fix. No guarantee but should work. 3 7 Share this post Link to post Share on other sites
kpinnc 13,105 #15 Posted November 10, 2023 Before I used JB weld, I'd have a nut brazed on. It would outlast JB weld, and be quite a bit stronger. 6 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,176 #16 Posted November 10, 2023 An Allen head socket cap screw is usually Grade 8 material so very hard to machine. 3 Share this post Link to post Share on other sites
Wild Bill 633 862 #17 Posted November 10, 2023 (edited) @ebinmaine I recommend using an E-Z Lok threaded insert. The 1/4-20 internally threaded thin wall insert has an external thread of 3/8-16 and the standard wall insert has an external thread of 7/16-14. Then use a 1/4-20 X 3/4 long dog point set screw for the shifter. Edited November 10, 2023 by Wild Bill 633 6 3 Share this post Link to post Share on other sites
WHX?? 49,919 #18 Posted November 10, 2023 (edited) Really good idea Dan ... now you know we pay you... Easy peasy if the tranny is off frame. Can be found in the Hillman drawers mild steel @gwest_ca I've got a three piece RJ tranny that needs this fix. Have to look those up @Wild Bill 633... not familiar. Edited November 10, 2023 by WHX?? 2 1 Share this post Link to post Share on other sites
JimSraj 471 #19 Posted November 10, 2023 Hope you let us know what you decide to do and how well it works out for you. For what it’s worth, I like achto’s idea. Most likely need to flush up the inside as well once the loctite sets up. 2 Share this post Link to post Share on other sites
ebinmaine 69,710 #20 Posted November 10, 2023 6 hours ago, JimSraj said: Hope you let us know what you decide to do and how well it works out for you. I'll try to remember to post what I do here. 2 Share this post Link to post Share on other sites
Retired Wrencher 5,590 #21 Posted November 10, 2023 Eric this holds the shift lever in place? I have a few of the set screws I can send up with the carb! 3 1 Share this post Link to post Share on other sites
ebinmaine 69,710 #22 Posted November 10, 2023 55 minutes ago, Retired Wrencher said: Eric this holds the shift lever in place? I have a few of the set screws I can send up with the carb! I've got some here too. But I'd like to see what you use. 1 Share this post Link to post Share on other sites
953 nut 56,742 #23 Posted November 10, 2023 11 hours ago, gwest_ca said: An Allen head socket cap screw is usually Grade 8 material so very hard to machine. If a hardened steel or grade 8 item is heated to red hot and allowed to cool slowly it can be drilled and tapped. I have done this with broken or stripped out Allen Head set screws. 4 1 Share this post Link to post Share on other sites
Pullstart 63,529 #24 Posted November 10, 2023 I’m pretty late to the party, but I was thinking the same as Dan. Loctite a bolt in there, then drill and tap a new hole. 4 Share this post Link to post Share on other sites
ACman 7,629 #25 Posted November 10, 2023 … that what I was thinking too before I read Dan’s post and beat me to it . Good luck on your venture . 3 Share this post Link to post Share on other sites
