Colby G
Charger 12
Colby G
Hello, I recently bought a charger 12 as a restoration project and was wondering how the brakes work, because when I depress the pedal, it seems to only put the tractor in neutral. Any info would be greatly appreciated.
ebinmaine
Hydro or manual transmission?
Colby G
Hydro
ebinmaine
So that should be made between 1968 and 1972 and it would have a Sundstrand transmission.
There is no actual mechanical brake on those.
The movement, or lack thereof, of the tractor is dictated strictly by the position of the motion control lever.
The brake pedal is linked as you see and it returns it to neutral which puts you to a position of little to no movement in either direction. Sometimes adjustment is necessary. Once the tractor is STOPPED there is a release for the belt which moves a lever inside the transmission locking a gear in place.
Colby G
Does it have to have an engine for this mechanism to work?
ebinmaine
In a way...
If the transmission is not being driven by the engine then there would be no fluid pressure to keep the tractor going forward or backwards, or in place.
The gear locking mechanism however would not need an engine.
daveoman1966
The 'brake' is applied by pulling UP on the lever next to your right knee.  Pulling UP on it engages the PARKING PAWL inside the gearbox ---AND--- simultaneously disengages the belt from the Engine pulley.  DO NOT EVER pull UP on this lever while in motion.  You WILL destroy gears inside the gearbox.... GUARANTEED!  Pull UP on this lever ONLY when at a FULL STOP.  It is, effectively, the same a putting your car into PARK.
Colby G
  On 11/7/2023 at 6:00 PM, ebinmaine said:
In a way...
Where is the belt release?
Colby G
And what if it still moves when this lever is pulled up?
Edited by Colby G
Colby G
I kinda figured it out, the mechanism isn't going up all the way. How do I fix it?
ebinmaine
Can you post pictures? Or do you have a YouTube account where you could post short videos?
Colby G
I have a youtube account where I could post a short video of it. The forum only lets me post a maximum of .86MB for some reason where before it let me do up to around 2.5MB. My channel name is atomic apex.
ebinmaine
This is where it pays to become a Redsquare Supporter.
Ads are gone.
Limits are gone.
And you help @nylyon keep this great site going.
Colby G
Ads are gone.
Limits are gone.
Id love to but I don't have the money to right now... Not with my tractors that need gas and stuff. It's does cost money to become a redsquare supporter, right?
Edited by Colby G
ebinmaine
I think it's $20 a year.
It's about prioritizing to the best place.
IMHO it's a better investment than a LOT of tractor parts or repairs.
That's 20 bucks you can spend KNOWING you'll get that much VALUE out of the knowledge.
Chances are you'll save that amount several times over by asking the right questions and doing repairs correctly the first time.
  • Excellent 2
Colby G
Maybe some day, I'm only in high school without a job is the problem, I do side jobs that don't pay that much...
pfrederi
First off you should download the owners manual for your tractor.   Free click on the fuzy picture to get the link.
The parking brake handles pulls up and locks into the braked position.  You have to push forward and down to release it.
If the tractor still rolls with the handle pulled up then the parking pawl inside the transmission is shot.
Edited by pfrederi
Colby G
I somewhat figured it out I think, I don't believe the handle is going up all the way. https://youtube.com/shorts/V6yMviatcKY?si=8vOtRDDoD3ATIEhV
pfrederi
If your handle will not stay up it appears the issues is the shiny bar spot on the arm and the pin that rides on it.  If you look at the bottom of the pin I bet it has a deep groove worn in it.  That need to be filled in and the arm (shiny part re shaped)
Colby G
What should the arm look like?
pfrederi
Edited by pfrederi
Colby G
  On 11/7/2023 at 7:15 PM, pfrederi said:
I have an old transmission with a better arm, how would I replace it? Or would it be easier to just reshape it?
Edited by Colby G
pfrederi
Disconnect the spring drive out the small roll pin pull the arm off the transmission shaft  Don't forget to fill in the groove that has worn into the pin (yellow circel)
Edited by pfrederi
Colby G
And how would I reshape the arm?
Colby G
Thank you to whoever gifted the one year supporter membership to me, you do not know how much it really means to me!
  • Heart 5
