Handy Don 13,340 #101 Posted November 24, 2023 You really have to decide how much it means to you to not have scratches & chips! 3 Share this post Link to post Share on other sites
OldWorkHorse 3,049 #102 Posted November 25, 2023 10 hours ago, Handy Don said: You really have to decide how much it means to you to not have scratches & chips! Haha it don't bother me to badly. But I'd like to reassemble it before it starts to chip and scratch 1 Share this post Link to post Share on other sites
kpinnc 13,716 #103 Posted November 25, 2023 On 11/24/2023 at 8:56 AM, cleat said: I bought some Krylon. That farm implement paint by Krylon is horrible. Runs like crazy, terrible coverage. I was so happy to find IH red, but quickly realized it just does not compare to even the no name dollar store stuff. Share this post Link to post Share on other sites
cleat 7,005 #104 Posted November 25, 2023 Masking papers removed. I will let this paint dry for a while before continuing on with the assembly of this machine. 7 Share this post Link to post Share on other sites
cleat 7,005 #105 Posted November 26, 2023 Engine plate installed. Engine sat into place then bolted down. Steering wheel is just temporarily installed with a bolt to make moving tractor around easier. I now need to figure out belt length as I am leaving the hydro pulley on the engine. I believe B80 is the hydro belt length so I will likely need a B81 or B82. 1 1 Share this post Link to post Share on other sites
cleat 7,005 #106 Posted November 26, 2023 Installed upper belt bracket / brake. 4 Share this post Link to post Share on other sites
cleat 7,005 #107 Posted November 27, 2023 Wire harness complete and ready to install. 3 2 Share this post Link to post Share on other sites
c-series don 9,424 #108 Posted November 28, 2023 @cleat I was wondering if you ever considered installing an electric lift instead of the manual lift for this build? I never understood why the 520-8’s didn’t come that way? Share this post Link to post Share on other sites
cleat 7,005 #109 Posted November 28, 2023 I have plenty of Hydro machines with power lift. Part of the reason for building this 8 speed one was to have a manual lift that I can set the down height for the mid mount blade. This machine won't get used a lot so my arm won't get too tired I don't think. 4 Share this post Link to post Share on other sites
ebinmaine 70,694 #111 Posted November 28, 2023 21 minutes ago, cleat said: This machine won't get used a lot so my arm won't get too tired I don't think You'll be good. That grader isn't super heavy 1 Share this post Link to post Share on other sites
c-series don 9,424 #112 Posted November 29, 2023 I certainly hope that you’re not going to put a mid-mount grader blade on that beautiful tractor that’s not painted to match. 🤣 I’m sorry, you probably have already reconditioned one, painted and lubed up ready to go!! 😂 Just busting chops! Your work is always nothing less than impressive 👍🏻Keep it up! 2 1 Share this post Link to post Share on other sites
cleat 7,005 #113 Posted November 29, 2023 Installed clutch idler pulley, safety switch, and belt. Took many trips to the store exchanging belts until I found the one that fit best although not perfect. Ended up with a B83. Installed right side foot rest and lower belt guide. 9 Share this post Link to post Share on other sites
cleat 7,005 #114 Posted November 29, 2023 11 hours ago, c-series don said: I certainly hope that you’re not going to put a mid-mount grader blade on that beautiful tractor that’s not painted to match. 🤣 I’m sorry, you probably have already reconditioned one, painted and lubed up ready to go!! 😂 Just busting chops! Your work is always nothing less than impressive 👍🏻Keep it up! Ha Ha. I hope this blade looks good enough. It's been used so not quite as nice now but still should work OK. 1 8 1 Share this post Link to post Share on other sites
c-series don 9,424 #115 Posted November 29, 2023 Baahh Ha Ha !!! I knew it!!!! 2 Share this post Link to post Share on other sites
ebinmaine 70,694 #116 Posted November 29, 2023 7 hours ago, cleat said: belts You got the larger engine pulley from the Hydro? Is that the extra belt length? 1 Share this post Link to post Share on other sites
cleat 7,005 #117 Posted November 29, 2023 11 minutes ago, ebinmaine said: You got the larger engine pulley from the Hydro? Is that the extra belt length? Yes, I don't have a smaller pulley here so I am going to see how the hydro pulley works. 1 Share this post Link to post Share on other sites
ebinmaine 70,694 #118 Posted November 29, 2023 Just now, cleat said: Yes, I don't have a smaller pulley here so I am going to see how the hydro pulley works. Methinks you'll like it. A bit extra top end speed. 1 Share this post Link to post Share on other sites
cleat 7,005 #119 Posted November 30, 2023 Fuel tank treated with back to black then installed. Fuel line ran but not hooked to fuel pump yet. 3 3 Share this post Link to post Share on other sites
cleat 7,005 #120 Posted November 30, 2023 Wire harness connectors lubed with silicone grease then harness installed. 1 7 Share this post Link to post Share on other sites
cleat 7,005 #121 Posted December 1, 2023 Plastic dash cover polished and installed. Left foot rest installed. Right foot rest and belt cover installed. Tunnel covers temporarily installed for fitment. They fit so next is to refinish these. Left side cover installed. Overview as of today. 2 4 Share this post Link to post Share on other sites
cleat 7,005 #122 Posted December 1, 2023 Rear hood stand plate and shift cover plate sanded. Rear hood stand plate and shift cover plate primed. Of course a bug immediately got in the primer even though it's barely above freezing out. 4 Share this post Link to post Share on other sites
ebinmaine 70,694 #123 Posted December 2, 2023 On 11/30/2023 at 10:54 AM, cleat said: Wire harness That green wire over the cross shaft .. Will there be enough (or any) movement there that could chafe the wire? 2 Share this post Link to post Share on other sites
lynnmor 7,557 #124 Posted December 2, 2023 9 minutes ago, ebinmaine said: That green wire over the cross shaft .. Will there be enough (or any) movement there that could chafe the wire? I believe that those wires are laying there just waiting for tail lights or a seat switch. 1 1 Share this post Link to post Share on other sites
cleat 7,005 #125 Posted December 2, 2023 10 minutes ago, ebinmaine said: That green wire over the cross shaft .. Will there be enough (or any) movement there that could chafe the wire? That is for the tail lights and will be secured better when the fender is installed. 2 1 Share this post Link to post Share on other sites
