WHX?? 50,510 #126 Posted December 5, 2023 On 12/5/2023 at 12:51 AM, 953 nut said: Looks like there are two roller bearings and an "O" ring for a seal. I thought they were needle bearings but definitely just a o ring for a seal. On 12/5/2023 at 1:03 AM, SylvanLakeWH said: First pic is what blew OK now I remember Sylvia... are you saying the orginal one blew? I saw those breakers too. Though the book said 70 Amp? 3 Share this post Link to post Share on other sites
SylvanLakeWH 27,193 #127 Posted December 5, 2023 (edited) The first pic above is the stock tin foil. That's what failed on the A-60. The second pic is the E9 70 amp circuit breaker I put in and it has worked perfectly. No trips. Edited December 5, 2023 by SylvanLakeWH 2 1 Share this post Link to post Share on other sites
Achto 28,586 #128 Posted December 5, 2023 On 12/5/2023 at 12:51 AM, 953 nut said: Jim, you are being too good to me. Jim just can't leave anything alone. Not one of his worst qualities though. I had to wrestle him down to keep him from tearing a plow apart that Jeff had bought and had delivered to plow day this year. Back to the fuse thing. I think that the re-set-able breaker is a much better option than the fuse is. 2 1 Share this post Link to post Share on other sites
953 nut 57,498 #129 Posted December 5, 2023 (edited) On 12/5/2023 at 1:16 AM, WHX?? said: I thought they were needle bearings but definitely just a o ring for a seal. You are correct, I should have said Needle bearings. But if i had said needle bearings you wouldn't be able to needle me about it! The new 70 amp breaker is on the way to @WHX??, Thanks for reminding us what worked for you @SylvanLakeWH Edited December 5, 2023 by 953 nut 1 Share this post Link to post Share on other sites
WHX?? 50,510 #130 Posted December 8, 2023 (edited) Fuel gauges came in today Richard. Work perfect. Do you want the volts scale or the colored one. It's the faded clear plastic that makes it hard to see. An easy swap and by no means permanent. Also I noticed that the gauge will read 24/7. Would it be wise to add a shut off switch? Not that it has a huge power draw. Again your call Richard. Edited December 8, 2023 by WHX?? 1 2 Share this post Link to post Share on other sites
953 nut 57,498 #131 Posted December 8, 2023 On 12/8/2023 at 9:47 PM, WHX?? said: Do you want the volts scale or the colored one. The colored one would be my preference. Since it is staying on I guess we should leave it disconnected over the winter, I will rewire it to operate with the key later. 1 Share this post Link to post Share on other sites
WHX?? 50,510 #132 Posted December 9, 2023 (edited) On 12/8/2023 at 11:59 PM, 953 nut said: The colored one would be my preference. Done... never give it a thought to try and wire it to the key. Wonder why WH didn’t do that? The wiring diagram does show it always hot but that's as far as I looked. I thought maybe just an on off switch on the column right next to the nitrous boost switch... BTW all Four corners holding air nicely. Shoulda took it out for a road test today. In the 50s and driveway clean. Got the twisted off bolt out @Achto and re-tapped. Edited December 9, 2023 by WHX?? 2 Share this post Link to post Share on other sites
953 nut 57,498 #133 Posted December 9, 2023 On 12/9/2023 at 12:11 AM, WHX?? said: right next to the nitrous boost switch. Have to think about it. Might be a bit risky to have the wife on a juiced up ! Not too sure how to add nitrous to an electric horse anyway. 4 Share this post Link to post Share on other sites
Achto 28,586 #134 Posted December 9, 2023 On 12/9/2023 at 12:49 AM, 953 nut said: Not too sure how to add nitrous to an electric horse anyway. A couple of Lipo batteries hidden under the wet cells should serve as a close equivalent. A flip of the switch changes 36v to 72v. On 12/9/2023 at 12:11 AM, WHX?? said: Got the twisted off bolt out @Achto and re-tapped. Thank Jim!! 1 1 Share this post Link to post Share on other sites
WHX?? 50,510 #135 Posted December 19, 2023 BTW Richard put away for a long winters nap. She's got good company. Covered with a bed sheet. I wired the fuel gauge to the load side of the breaker and tripped the breaker so it's not on. I tooled around on it abit before parking so will periodically start the charger. Sure does make a handy rig for running to the mailbox! 1 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,193 #136 Posted December 19, 2023 She looks lonely there... maybe i take that senior you're using for a clothes line - free up some space ya know - and you tuck her in tight next to the hood top tire storage tractor... 4 Share this post Link to post Share on other sites
WHX?? 50,510 #137 Posted December 20, 2023 (edited) On 12/19/2023 at 2:15 PM, SylvanLakeWH said: maybe i take that senior you're using for a clothes line Yours for 10k Sylvia and I doubt you have to outbid Pullstart who has dibs. No extra charge for the barn dust the clothes line does not keep off. Those are pricey Firestone 23s ... figured a would take them over a electric jobby.. Edited December 20, 2023 by WHX?? 1 3 Share this post Link to post Share on other sites
Achto 28,586 #138 Posted December 20, 2023 On 12/20/2023 at 12:07 AM, WHX?? said: Yours for 10k Sylvia and I doubt you have to outbid Pullstart who has dibs Too rich for my tight a##, I'd step down as second in line. 4 Share this post Link to post Share on other sites
WHX?? 50,510 #139 Posted December 20, 2023 That's not your price Dan ... just Sylvia's... well maybe Pullstarts too if he doesn’t quit buying $$ rigs for his wife. Second thought she deserves it living with him... 3 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,193 #140 Posted December 20, 2023 A Sad Haiku... @WHX??... for you: Sylvia is sad Discriminatory price No cheese curds for you 4 Share this post Link to post Share on other sites
WHX?? 50,510 #141 Posted December 20, 2023 On 12/20/2023 at 1:05 AM, SylvanLakeWH said: No cheese curds for you Got that right I'm a little backed up right now... visual... Just now, SylvanLakeWH said: 4 Share this post Link to post Share on other sites
SylvanLakeWH 27,193 #142 Posted December 20, 2023 4 Share this post Link to post Share on other sites
953 nut 57,498 #143 Posted June 23, 2024 Thanks to Jim @WHX?? and Dan @Achto who wrangled this little horse for me and for doing farrier duty putting new shoes on it, then transporting it to @Pullstart's plow Day and mike @Mike'sHorseBarn who delivered it to the Big Show and Mike @squonk and Randy @rjg854 and Don @Handy Don who loaded this little hose into my truck it is now home in my garage. 1 8 Share this post Link to post Share on other sites
Pullstart 64,381 #144 Posted June 23, 2024 Wheel Horse people are the best people! I am resting and enjoying my family today, but will post up a video of Richard cruising this soon! 2 1 Share this post Link to post Share on other sites
WHX?? 50,510 #145 Posted June 24, 2024 No problem at all Richard we had fun doing it. I don't remember if I told you but just before I loaded it up for Pullstart's I went to top off the batteries and sparks in the charger and went dead. Hopefully nothing serious keep us posted. Hope your happy with it is a cool little rig. On 6/23/2024 at 9:04 PM, Pullstart said: , but will post up a video of Richard cruising this soon! YES!!! 1 Share this post Link to post Share on other sites
953 nut 57,498 #146 Posted June 24, 2024 On 6/24/2024 at 3:37 AM, WHX?? said: sparks in the charger and went dead Mike @Mike'sHorseBarn told me about that. My guess is a fifty year old capacitor probably bit the dust. When I get into it I will add the information to this post and do an instructional thread. 2 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,193 #147 Posted June 24, 2024 On 6/24/2024 at 11:40 AM, 953 nut said: Mike @Mike'sHorseBarn told me about that. My guess is a fifty year old capacitor probably bit the dust. When I get into it I will add the information to this post and do an instructional thread. I'll be interested for sure... Thx! By the way, there may or may not have been Capt'n involved in the various stages of storage, transport, loading, unloading and general handling of your little ... Some shady characters up nort in Wisconsin... 6 Share this post Link to post Share on other sites
