Wheel Horse 3D
Loader plus posthole auger????
Wheel Horse 3D
The thought is: has anyone ever attached an augers with it's own power to their bucket???
Was thinking, with forks I could space them to nicely hold the unit, ratchet strap that puppy, an rig a way to operate the throttle.
Manhandling that auger is getting quite difficult!
953 nut
Keeping the auger vertical and centered in the hole could be a bit challenging as the bucket is lowered. It goes down in an arc rather than a straight line.
Wheel Horse 3D
True, I had thought of a pivot if I wanted to do some fabrication, but manually leveling isn't too bad.
953 nut
When I lived in Homestead Florida I rented a post hole digger like the one pictured below. With the engine located away from the auger it made boarting a hole in coral rock a lot more doable. had to start with a two inch auger then switch off to a six inch, the six inch by itself wouldn't do anything.
wallfish
That should work. Throttle shouldn't be too hard
Used to have this cool machine for doing post holes. Did my 6 holes and then sold it
Lee1977
Build a fork-lift to mount it to, then you have two pieces of equipment.
