Rick Ferrucci
Dashboard housing metal
Rick Ferrucci
I think I'll be able to mount some rear view mirrors onto my GT14 dashboard housing. I can  see that it's cast, but I don't know if it's steel or iron. Has anyone tried to drill into the the dash housing? Was it drillable? Thanks for help.
leabassett@sbcglobal.net
If it is cast it will look like coffee grinds when drilled. Steel will give you a birds nest when drilled.
  • Like 3
Achto
  On 11/4/2023 at 9:41 PM, Rick Ferrucci said:
Was it drillable?
It should drill & tap very easily.
WHX??
I wish you guys would not encourage guys to remove metal from old tractors!... :lol:
  • Like 3
  • Haha 3
Lee1977
It's Pot Metal a mixture of non-ferrous metals that is easy to cast. I would not mount anything that could get hit as It not something that Is easy to fix and it's not strong.
Edited by Lee1977
  • Like 4
Rick Ferrucci
Thanks for the tips about this dash housing. I haven't drilled into it yet.
  • Similar Content
    • Schmendrickthemagnificent
      By Schmendrickthemagnificent
      Thoughts and opinions on how to mount a Predator engine on a wheel horse 657, was kinda hoping the mounting bracket would work from the previous engine which apparently looks like a Tecumseh h50 with a Craftsman part number so who knows where it came from... so do I just buy a universal plate from amazon or ebay and drill some holes, find some metal and make one, dunno if anyone has bothered to go thru this already and had a good suggestion or anything I should know about... Thx
    • Mithral
      By Mithral
      Seeking guidance for tuning a CH18S Kohler Command (1995), as replacement for a 16hp Onan (1990).
      This Kohler doesn't have the torque-grunt of this Onan, but it works, and is my available option.
      So, how best to tune the Kohler for this application?
      1. I believe Onan and Kohler high RPM setting are both 3600?
      2. Would it hurt the Kohler to boost that RPM to 3700-3800?   Would it really help any?
      3. Would it hurt the Hydro Transmission to go over 3600rpm?
      4.  I guess I could go find a slightly smaller Drive Pulley?  And what would then happen to the Trans if I can't get the proper RPMs to the Trans?
      Now that I've figured out the mounting arrangements I can always swap in a bigger engine should I stumble upon a better option.
      Given the difficulties of getting the Onan rebuilt now-a-days, I'm looking to go for a more modern engine with easier to find parts/service.  And I'm not inclined to do an engine rebuild myself.
      Thanks,
      - L.
    • Bach-Ed
      By Bach-Ed
      Before I re-invent the wheel, I'll ask.  I'm putting a CH270 Kohler on my 857 to replace the trashed K engine.  It appears the throttle cable needs to enter at the right side rear of the engine, instead of at the front on the K.  I know there are a multitude of brackets that would make the job relatively simple.  BUT where would I find details and where to order them from.  If push comes to shove I'll fab something but I have a feeling a "factory" bracket would  be a lot less work and need less refining.
      I know you all like photos so here are a couple.  The last one shows how I think the cable will eventually run, maybe?  Or will some kind of bell crank be the ticket?
      Ed
